2960 queue drops
network1215
I am looking at out "show mls qos int gig 1/0/12 statistics" and wonder if should be concerned about the outs in "
  output queues dropped" at the bottom of output.
There is qos enabled.
Q: how do I identify which packets getting dropped ? looking at "output queues dropped"
Q: I did see "Total output drops" on this interface in numbers "8829" but cleared the interface counters, now see 0 drops ? is this relevant to  "output queues dropped"
GigabitEthernet1/0/12 (All statistics are in packets)
  dscp: incoming
  0 -  4 :    61531446            0            0            0            0
  5 -  9 :           0            0            0            0            0
 10 - 14 :       15716            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0            0
 25 - 29 :           0     11900048            0            0            0
 30 - 34 :           0            0       786481            0            0
 35 - 39 :           0            0            0            0            0
 40 - 44 :           0            0            0            0            0
 45 - 49 :           0     35380561            0            0            0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :     8988344        22094       367300           16       154664
  5 -  9 :           2           43            7     10066779            0
 10 - 14 :      133785            1            1            1           36
 15 - 19 :           2          364            0          652            8
 20 - 24 :          16            6            2            2         9572
 25 - 29 :           5     19272391           63            4            5
 30 - 34 :           3           10       716074            6            2
 35 - 39 :          19           38            0         2923            0
 40 - 44 :           9            5           16            0          214
 45 - 49 :           2     33596334            2     41570000            1
 50 - 54 :           0           22            1            4           24
 55 - 59 :           5       165835            4            4            2
 60 - 64 :           9            3            3            0
  cos: incoming
  0 -  4 :   421002324            0            0      8712888            0
  5 -  7 :    28608651            0            0
  cos: outgoing
  0 -  4 :  1604303796       707487     74346632      2382218     12776147
  5 -  7 :    20089626     68293948     30691975
  output queues enqueued:
 queue:    threshold1   threshold2   threshold3
 queue 0:           0           0      791100
 queue 1:   260896088   385956391   132126554
 queue 2:           0           0    11110999
 queue 3:      183863         257  1107952031
  output queues dropped:
 queue 0:           0           0           0
 queue 1:        2484           0           0
 queue 2:           0           0       11683
queue 3:        1002           0      382426
Policer: Inprofile:      1817873 OutofProfile:         1132
show int gig 1/0/12
GigabitEthernet1/0/12 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 84b5.1782.7444 (bia 84b5.1782.7444)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:08, output 00:00:01, output hang never
  Last clearing of "show interface" counters 00:02:00
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 30000 bits/sec, 33 packets/sec
     29 packets input, 4098 bytes, 0 no buffer
     Received 6 broadcasts (6 multicasts)
     0 watchdog, 6 multicast, 0 pause input
     4157 packets output, 485267 bytes, 0 underruns
     4 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Hello
Possible historical - Can you post the output of the following:
sh mls qos queue-set
sh mls qos input-queue
sh mls qos interface gig1/0/12 queuing
Kind Regards
Paul
sh mls qos input-queue (didn't work)
Queueset: 1
Queue     :       1       2       3       4
buffers   :      15      30      45      10
threshold1:      60      80     100     100
threshold2:     100      90     100     100
reserved  :     100     100      50      50
maximum   :     400     400     400     400
Queueset: 2
Queue     :       1       2       3       4
buffers   :      25      25      25      25
threshold1:     100     200     100     100
threshold2:     100     200     100     100
reserved  :      50      50      50      50
sh mls qos interface gig1/0/12 queueing
Egress Priority Queue : enabled
Shaped queue weights (absolute) :  15 0 0 0
Shared queue weights  :  1 15 30 15
The port bandwidth limit : 100  (Operational Bandwidth:100.0)
The port is mapped to qset : 1
in addition below is the configuration:
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 34 40 46
mls qos srr-queue output dscp-map queue 2 threshold 1 16 18 20 22 26 28 30 36
mls qos srr-queue output dscp-map queue 2 threshold 1 38
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 3 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 60 100 100 400
mls qos queue-set output 1 threshold 2 80 90 100 400
mls qos queue-set output 1 buffers 15 30 45 10
thanks Paul
curious if you did get a chance to look into configuration
Joseph W. Doherty
". . . wonder if should be concerned about the outs in output queues dropped" at the bottom of output."
Concerned? That depends. Generally it's worth determining if drops are detrimental to your network applications who are losing those packets. However, also generally, very low drop rates are not detrimental. Drop rate impact does vary between network applications.
"Q: how do I identify which packets getting dropped ? looking at "output queues dropped""
That depends on you "knowing" what traffic gets into the queues which are accumulating drops.
"Q: I did see "Total output drops" on this interface in numbers "8829" but cleared the interface counters, now see 0 drops ? is this relevant to "output queues dropped" "
On low-end switches, interface drop stats don't always reflect ASIC drops. (Sometimes ASIC stats have errors too.) Using a "solid" IOS version is your best bet for accurate stats.
