Hi guys,
I have disconnected the fan of a 2960-S because it was a little bit too noisy (is laying next to me on a board). Before I created monitoring sensors in PRTG to check the temp. After the weekend I recognized the temp sensor was in warning state (was expecting that) but couriously the fan sensor was still green. I checked out the switch console and the fan sensor shows FAN is OK. So what's going on? Sensor should be faulty or not present. Means to me the fan monitoring is not very helpful (for this type).
Does anyone has figured the same issue or has any helpful information?
Jens
