2960 - SDM
Sivakanth Akkapu
Community Member
What is the difference between  sdm prefer access & sdm prefer default & sdm prefer lanbase-routing?
When do we use these options?
cadet alain
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swsdm.html#wp1221370
Access is support for large number of ACLs but it is not talked about in the previous link, is it supported on 2960 ?.
Regards.
Alain
Hi Alain,
yes, three options supports on 2960S switchs
