2960 srr-queue command
Don Diep
Visitor
I have a 2960 running with version
Cisco IOS Software, C2960 Software (C2960-LANLITEK9-M), Version 15.0(2)SE5, RELEASE SOFTWARE (fc1)
srr-queue command is not support under interface
switch(config-if)#srr?
% Unrecognized command
Does 15.0.2 version support it?
nspasov
Hi Don-
I believe the issue is not with the version but the type of Image that you have. It appears that "Lanlite" does not include the advanced QOS features such as the "shaped-round-robin" You will need to upgrade that to at least a "LAN-Base"
You can check this and any similar requests by using Cisco's Feature Navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Thank you for rating helpful posts!
