2960 switch - junk login credential accepting
I am testing access switches for one project, I notice when i telnet from core to access and instead of appropriate username if i give some junk characters like shown in below output. Its accepting that username and not asking for password and landing me to the user-exec (>) mode.
CORE-SW#telnet 192.168.1.50
Trying 192.168.1.50 ... Open
User Access Verification
Username: aldkfjadfdslkdja
ACC-SW1>
I update the IOS of the switch as well as per Cisco recommended IOS but output is same.
Switch Model No: WS-C2960S-48FPS-L
Switch IOS Version: 15.2(2a)E1 | C2960S-UNIVERSALK9-M | flash:/c2960s-universalk9-mz.152-2a.E1/c2960s-universalk9-mz.152-2a.E1.bin"
Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE
Show version Output
-SW2#show version
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.2(2a)E1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 10-Dec-14 03:54 by prod_rel_team
ROM: Bootstrap program is C2960S board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
RUHHR-G-F9C1-SW2 uptime is 2 weeks, 2 days, 3 hours, 39 minutes
System restarted at 09:32:47 Riyadh Tue Dec 27 2016
System image file is "flash:/c2960s-universalk9-mz.152-2a.E1/c2960s-universalk9-mz.152-2a.E1.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48FPS-L (PowerPC) processor (revision B0) with 131072K bytes of memory.
Processor board ID
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address :
Motherboard assembly number :
Power supply part number : 341-0382-02
Motherboard serial number :
Power supply serial number :
Model revision number : B0
Motherboard revision number : A0
Model number : WS-C2960S-48FPS-L
Daughterboard assembly number : 73-11933-04
Daughterboard serial number :
System serial number :
Top Assembly Part Number : 800-32647-02
Top Assembly Revision Number : A0
Version ID : V02
CLEI Code Number : COMGB00ARB
Daughterboard revision number : A0
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960S-48FPS-L 15.2(2a)E1 C2960S-UNIVERSALK9-M
Configuration register is 0xF
Brian Beijl
What kind of security is in place for allowing access to the switch? Are you using aaa, radius, tacacs, or is this an out-of-the-box switch with barely any configuration? Even in the last case, it should not accept any bogus usernames.
At minimum you should have the command "login local" under the line vty 0 15 instances.
Curious to know what relevant config is used..
Brian
Found the Culprit.
aaa authentication login default local none
Removed none from the above command and problem is fixed.
