08-03-2021 06:17 AM - edited 08-03-2021 06:47 AM
Hi All,
Can I go straight from 15.0.2a-EX5 to 15.2.7E4? I can't find any documentation where It is described/confirmed.
Thanks for reply.
Jakub
Solved! Go to Solution.
08-03-2021 10:44 AM
yes you can jump directly, make sure to check release notes for any config / command changes.
## Make sure to mark post as helpful, If it resolved your issue. ##
08-03-2021 05:15 PM
Direct upgrade to 15.2(7)E train is possible, HOWEVER, I strongly recommend doing a COLD REBOOT (pull the power cable) instead of issuing the "reload" command.
08-03-2021 09:39 AM
- Start by reading the Release Notes of the targeted version, look for upgrade and installation guidelines.
M.
08-04-2021 01:03 AM
Thank You for Your advice. I checked release notes before post for help. If there is some document where I can find exact answer, could You please paste link?
JL.
08-03-2021 10:44 AM
08-04-2021 01:05 AM
Thank You.
Of course before upgrade all will be checked. I was just not sure about direct path.
08-03-2021 05:15 PM
08-04-2021 01:13 AM
Thank You for reply.
During research I saw that sometimes are issues during reload where solution is cold reboot. Thanks for this advice.
01-17-2024 11:44 AM
Hello Leo,
Can I go straight from 15.0.2a-EX5 to 15.2.7E7? I can't find any documentation where It is described/confirmed.
Appreciate your comments.
Regards.
01-17-2024 02:48 PM
Yes, it is possible and very much supported.
HOWEVER, a would like to put a word of warning. 2960X/XR is one of the most heavily sold as counterfeit. The only time users find out the 2960X is a counterfeit is when the switch firmware gets updated (and bricks the switch).
Look at the Purchase Order or the delivery docket of the switch to confirm it is not counterfeit. If it is not, upgrade away.
If you believe the unit is counterfeit, contact Cisco Counterfeit Protection team for assistance. They will not go after you but, rather, they want to know where did counterfeit switches come from (the source).
