2960x flexstacks general trend in average response times increasing, what could be causing this? any loops on the server hosts are due to round robin config on the host.
SultanLone2361
Any ideas what could be causing the response times to go up the POE switch has only been installed 6 weeks ago and it seems we are having slowness on the network. We have a VMhost which is flapping but this is the only one left the other storage devices I have unplugged off the network.
The attached are from solarwinds.
11 Replies 11
Leo Laohoo
Not helpful.
No useful information to start with.
What information would you need?
ios is bare image bin file 15.2-2 e7 issue only started after 6weeks of install.
only happening on 2 out of 4 switches in a stack, the master and member 2.
Describe this.
A server?  Connected to an access switch not designed for server work?
Post the complete output to the command "sh interface <SERVER PORTS> controller".  We want to see the output to all the ports connected to the server.
"sh run interface <Server PORTS>".
Show logs
Let's start with these.
how many switches are in the stack ? Try and reseat the stack modules, and check the cabling. Also, check the output of:
Switch#show switch stack-ring speed
and make sure the ring speed is the same on all member switches.
x4 as I have posted above.
Master:
sh switch stack-ring speed
Stack Ring Speed : 20G
Stack Ring Configuration: Full
Stack Ring Protocol : FlexStack
it might be one bad stack module or stack cable, try to narrow it down by removing and reinserting them one by one...
Thanks for your response, I cannot unplug stack cables right now in a live environment but I know its only two switches which are having this issue. So possibly could try this out of hours, Master and member 2 are the ones causing the intermittent network drops. Sorry for the poor diagram.
All 4 switches in stack show same speed 20G
cisco have sent replacements x2, it will be interesting to see behaviour once they are in.
Hello
I assume you've checked for any flooding/broadcasts span/rspan sessions or any frequent spanning-tree recalculations/convergences impeding connectivity?
Kind Regards
Paul
Hi Paul,
There has not been any re convergence on spanning tree the Root bridges remain as they were.
I know where the broadcasts are currently this is something that needs to be "managed" out of the network.
We have not SPAN ports or RSPAN I had one but removed this.
The wierd part of the network drop is that the phone does not loose connection only internal application drops and outlook 0365, but if you do a continous ping at the time to google or to the app server you will not see a lost packet.
thanks
