2960X Not sending Netflow
guy tec
Hi Everyone,
I have an issue with Netflow lite when testing it on a 2960X.
It seems that no flows are send to my collector.
Below the relevant config and som show outputs.
Can someone see what I did wrong or guid me to find a solution?
Thanks!
flow record record1
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect interface input
collect counter bytes long
collect counter packets long
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter export1
destination 10.10.10.130
template data timeout 60
flow monitor monitor1
record record1
exporter export1
cache timeout inactive 120
cache timeout active 300
sampler sampler1
mode random 1 out-of 100
interface GigabitEthernet1/0/1
ip flow monitor monitor1 sampler sampler1 input
Show commands:
test-2960#show ip flow export
Flow export v1 is disabled for main cache
  Version 1 flow records
  0 flows exported in 0 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
test-2960#show ip flow export template
No Template export information
No Option Templates exist
   Template Options Flag = 0
   Total number of Templates added = 0
   Total active Templates = 0
   Flow Templates active = 0
   Flow Templates added = 0
   Option Templates active = 0
   Option  Templates added = 0
   Template ager polls = 0
   Option Template ager polls = 0
Main cache version 9 export is disabled
test-2960#show flow exporter
Flow Exporter export1:
  Description:              User defined
  Export protocol:          NetFlow Version 9
  Transport Configuration:
    Destination IP address: 10.10.10.130
    Source IP address:      10.10.10.134
    Transport Protocol:     UDP
    Destination Port:       9995
    Source Port:            53881
    DSCP:                   0x0
    TTL:                    255
    Output Features:        Not Used
test-2960#show flow exporter statistics
  Packet send statistics (last cleared 1w1d ago):
    Successfully sent:         0                     (0 bytes)
    Enqueued to process level: 13823                 (1342365 bytes)
  Client send statistics:
    Client: Flow Monitor monitor1
      Records added:           20
        - sent:                20
      Bytes added:             820
        - sent:                820
jakewilson
Here is a config that worked with the 2960x switch that Cisco sent us for testing:
http://www.plixer.com/blog/netflow-lite-2/cisco-2960-x-netflow-lite-configuration/
Jake
