2960x qos to limit port-bandwidth
mr.marslin
Dears,
I want to limit the bandwidth 50M per port on 2960x switch.
Config:
class-map match-all CLASS_50M
 match access-group name ACL_50M
policy-map POLICY_50M
 class CLASS_50M
  police 50000000 1000000 exceed-action drop
ip access-list extended ACL_50M
 permit ip any any
interface GigabitEthernet1/0/35
 switchport access vlan 64
 switchport mode access
 load-interval 30
 storm-control broadcast level pps 100
 storm-control action trap
 service-policy input POLICY_50M
But, not any hit policy-map & acl ~
sh policy-map interface gigabitEthernet 1/0/35
  Service-policy input: POLICY_50M
    Class-map: CLASS_50M (match-all)
      0 packets, 0 bytes
      30 second offered rate 0000 bps, drop rate 0000 bps
      Match: access-group name ACL_50M
Have something wrong ?
acampbell
On the 2960-x look at the correct cofig guide for your
IOS Version.
Example 15.2.2E
Monitoring Standard QoS
Table 17 Commands for Monitoring Standard QoS on the Switch
Command
Description
show class-map [class-map-name]
Displays QoS class maps, which define the match criteria to classify traffic.
show mls qos
Displays global QoS configuration information.
show mls qos aggregate-policer [aggregate-policer-name]
Displays the aggregate policer configuration.
show mls qos interface [interface-id] [buffers | policers | queueing | statistics]
Displays QoS information at the port level, including the buffer allocation, which ports have configured policers, the queueing strategy, and the ingress and egress statistics.
show mls qos maps [cos-dscp | |cos-output-q | dscp-cos | |dscp-mutation dscp-mutation-name | dscp-output-q | ip-prec-dscp | policed-dscp]
Displays QoS mapping information.
show mls qos queue-set [qset-id]
Displays QoS settings for the egress queues.
show policy-map [policy-map-name [class class-map-name]]
Displays QoS policy maps, which define classification criteria for incoming traffic.
Do not use the show policy-map interface privileged EXEC command to display classification information for incoming traffic. The control-plane and interface keywords are not supported, and the statistics shown in the display should be ignored.
show running-config | include rewrite
Displays the DSCP transparency setting.
show policy-map interface command is NOT supported
Alex
Regards, Alex. Please rate useful posts.
