2960X stack issue
roshankadam7077
Frequent Visitor
Frequent Visitor
one of the 2960X switch in stack of 5 switches booted with new IOS and other with old IOS only when boot varibale is set with new IOS and strange thing is still connected in stack and whole stack working properly
10 Replies 10
balaji.bandi
You may be seeing the logs member mismatch IOS Code, seen that myself some rare case, but still works.
#show switch (give you that mismatch version information)
If that is member ok to work but if that is as standby some of the commands changed, you will have issue when the master fails and switch to new version (of the switch as master)  either lower the version of the switch to inline with stack, or upgrade all members higher version - i prefer to go latest version, may have security fixes
Note : not sure the version of code you running, i have given in general suggestion.
BB
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master 009a.d290.e880 15 4 Ready
2 Member 009a.d221.7400 5 4 Ready
3 Member 009a.d223.3600 1 4 Ready
4 Member 00c1.b1f8.c580 8 4 Ready
5 Member 009a.d29f.9500 12 4 Ready
Switch Ports Model SW Version SW Image
* 1 54 WS-C2960X-48LPD-L 15.2(7)E4 C2960X-UNIVERSALK9-M
2 30 WS-C2960X-24PS-L 15.2(7)E4 C2960X-UNIVERSALK9-M
3 54 WS-C2960X-48LPS-L 15.2(7)E4 C2960X-UNIVERSALK9-M
4 54 WS-C2960X-48LPS-L 15.2(7)E4 C2960X-UNIVERSALK9-M
5 54 WS-C2960X-48LPD-L 15.2(7)E10 C2960X-UNIVERSALK9-M
in above reply message switch number 5 booted with new IOS and joined stack. now we are planning to upgrade complete stack on 15.2(7)E10 version.
That's fine.
as new IOS is already in switches flash and boot variable is set so if we reload the complete stack will all switches comes up with new IOS?
sub-number is ok, not the major version mismatch here.
BB
do you think after setting boot variable with new IOS and reloading the complete stack will it boot with new IOS?
Not only boot variable the image should be available in the switches should work all stack member switches.
BB
MR.Cisco
Community Member
you must delete the os of this switch and run new boot  on rommon  of  switch  then boot it and reload switch with new os .
Joseph W. Doherty
I suspect the 2960X might work as the 3750 series did when it did allow different IOS images to run on different stack members, with a correctly functioning stack.  What would NOT work was if the different IOSs had different, major version numbers, stack code (not to be confused with IOS version numbers).  I recall if there was a difference in the minor version numbers, again for the stack code, device would throw a log message, during boot up.
A good rule of thumb was to insure all members were running the same IOS release (although, again on the 3750 series, they also did not need to have the same feature sets).
I believe later series Cisco stackable switches are more demanding requiring all stack members run identical code with identical features (licensing) too.
There's also, I believe, support to automatically push a stack's running code to a booting stack member without that image.  (I believe I've read the later series [or later IOSs?] handle dynamically loading a booting stack member's running software much better.)
Since you've already have a running stack member, I would presume there's still a way to update an IOS (and bootvar) on a specific stack member, and if necessary reload just that stack member.
Or, confirm whether your stack supports the dynamic push of an IOS to a booting stack member, and if it does, determine why it's not happening.
Lastly, if you "install" an IOS onto the stack, I believe it's supposed to make all necessary changes across all the stack members.
