2960X stack ring speed at 20G?
m.yost
I just received my first shipment of 2960X's and am noticing the stack ring speed isn't showing what I would expect.  I have (6)
WS-C2960X-48LPD-L in a stack.  There are no 2960S' in the stack where it would get downgraded.  Here is the output from a few commands...I would expect the Stack Ring Speed to be 80Gbps and the protocol to be FlexStack-Plus.
Switch#sh sw stack-ring speed
Stack Ring Speed        : 20G
Stack Ring Configuration: Full
Stack Ring Protocol     : FlexStack
Switch#sh sw det
Switch/Stack Mac Address : 7c95.f3ef.1300
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 7c95.f3ef.1300     15     4       Ready
2       Member 5017.fff0.d880     13     4       Ready
3       Member e8ed.f3b3.3880     11     4       Ready
4       Member 5017.ff41.e200     9      4       Ready
5       Member 5017.fff0.eb80     7      4       Ready
6       Member e8ed.f3b3.3600     5      4       Ready
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1        Ok         Ok                6        2
  2        Ok         Ok                1        3
  3        Ok         Ok                2        4
  4        Ok         Ok                3        5
  5        Ok         Ok                4        6
  6        Ok         Ok                5        1
Marvin Rhoads
20 Gbps is the correct port speed for a homogeneous 2960X stack. Reference.
The 80 Gbps number from the data sheets is "bandwidth" figured in Cisco's marketing way - two rings full duplex means the bandwidth is 4x the port speed.
Thats why my pre-sales guy and I figured it was.  Marketing speak.  You would think that they would say in the show commands that the protocol is actually FlexStack-Plus though!
I can't find the presentation right now but there was a similar one on the 3850 that I remember explaining how they came up with the numbers they use to market the stack speed. Probably a partner deep dive session.
Yes, I agree the show command should indicate the "Plus". Maybe you can get the TAC to accept the discrepancy as a cosmetic bug.
Edit - look at BRKARC-3448 on CiscoLive365 re the 3850. Slides 38, 86 and 91 shows how a 40 Gbps port speed translates to "480 Gbps" stack speed. (3 rings eastbound plus 3 rings westbound x 2 due to spatial reuse). I believe the 2960 is similar but with with a single ring eastbound and westbound x 2 for spatial reuse.
Message was edited by: Marvin Rhoads
