2960X stack speed.
kmolino6294
Visitor
I have a 2960X switch that has the stack speed at 10G. I can't for the life of me figure out how to set it back to 20G. Thanks for your help, Joe.
You can revert the speed back to 20G (default) via the (global) configuration command:
"no sw stack port-speed"
Best regards,
Antonin
adawa
Level 7
Level 7
Hello, kmolino6294.
I assume you already have the FlexStack module on each of your 2960-X switches? You can also check FlexStack-Plus for a higher stack throughput.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/white_paper_c11-728327.html
Let me know if you have additional concerns or e-mail ([email protected]) me directly. Kind regards.
All switches have a module and all are using the same version.
I am trying to change the Stack Ring Speed below from 10G to 20G.
Switch#show switch stack-ring speed
Stack Ring Speed        : 10G
Stack Ring Configuration: Down
Stack Ring Protocol     : FlexStack
Switch#
The other 2 switches are 20G.
Thanks for your help. Joe.
Best regards,
Antonin
Thank you very much! Joe.
