2960X stack switch with WD Storage ( unable achieve dual 1000M link)
KIAN SHUEN LIM
Hi all,
This would be a weird and specific scenario. We are running 2960X in stacking, IOS version 15.0(2)EX5
There is a WD MyCloud EX4 NAS storage come with 2 gigabit ports.
No matter what is the network configuration and load balancing mode (adaptive load balance / 802.3ad / non-redundancy) on EX4, we notice the port is running
LAN1  (EX4) connect to gi1/0/2 (100M,full)
LAN2 (EX4) connect to gi2/0/2 (1000M, full)
Yes we have tried to swap the cable and replace new CAT6 cable ( 5m), the behavior is still the same.
While I hardcode the link speed on EX4 to 1000:
GI1/0/2 ( disconnect)
GI2/0/2 ( 1000M full)
Initially we thought it was EX4's issue, so i connect LAN1 and LAN2 to another HP 1910-48G switch.
It is magically working fine, both port connected at 1000M full.
port configuration:
switchport mode access
switchport nonegotiate
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree guard root
switchport port-security
switchport port-security aging time 10
tried disable port-security but it wont help
Hello
And both switches in that 2960 stack support 1gb correct? -
If you swap the connections around do you still get the same output?
Have you tried to defaulting the ports
conf t
default int range gig1/0/2 , gig2/0/2
siwtchport host
By the way  do you really need spanning-tree bpdufilter enabled on the interface?
res
Paul
Kind Regards
Paul
Thanks Paul for the hint,
I default the port, unfortunately the outcome it still same.
CORE-SWITCH#show running-config interface gi1/0/2
Building configuration...
Current configuration : 38 bytes
interface GigabitEthernet1/0/2
end
CORE-SWITCH#show running-config interface gi2/0/2
interface GigabitEthernet2/0/2
end
CORE-SWITCH#show int gi1/0/2 controller
GigabitEthernet1/0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 1cde.a789.3d02 (bia 1cde.a789.3d02)
  MTU 9198 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 17:03:28, output 00:00:01, output hang never
  Last clearing of "show interface" counters 1w0d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 2 packets/sec
  5 minute output rate 16000 bits/sec, 8 packets/sec
     9693 packets input, 695032 bytes, 0 no buffer
     Received 139 broadcasts (86 multicasts)
     0 watchdog, 86 multicast, 0 pause input
     850225 packets output, 155691328 bytes, 0 underruns
CORE-SWITCH#show inter gigabitEthernet 2/0/2
GigabitEthernet2/0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 1cde.a7ac.9382 (bia 1cde.a7ac.9382)
  MTU 9198 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  Last input never, output 00:00:12, output hang never
  5 minute output rate 13000 bits/sec, 11 packets/sec
     2707180010 packets input, 3008608637999 bytes, 0 no buffer
     Received 193618 broadcasts (183830 multicasts)
     0 watchdog, 183830 multicast, 0 pause input
     1928180072 packets output, 1976470705058 bytes, 0 underruns
     0 output errors, 0 collisions, 6 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
however when I unplug 1/0/2 and plug to 2/0/24
CORE-SWITCH(config)#do show int gi2/0/24
GigabitEthernet2/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 1cde.a7ac.9398 (bia 1cde.a7ac.9398)
  Last input never, output 00:00:11, output hang never
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 121000 bits/sec, 60 packets/sec
     2872 packets input, 353627 bytes, 0 no buffer
     Received 46 broadcasts (46 multicasts)
     0 watchdog, 46 multicast, 0 pause input
     39631 packets output, 8988217 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
  Last input never, output 00:00:21, output hang never
  5 minute output rate 117000 bits/sec, 59 packets/sec
     2707182297 packets input, 3008608904018 bytes, 0 no buffer
     Received 193693 broadcasts (183902 multicasts)
     0 watchdog, 183902 multicast, 0 pause input
     1928216888 packets output, 1976479270029 bytes, 0 underruns
KIAN SHUEN LIM
beside speed and duplex what are other configuration can effect ethernet layer?
Appreciate some help up
