2960X stuck in boot loop
Dqslime
Hey everyone,
I need some major help please.
I have a ws-c2960x-48fps-l.
The issue I'm having is after it loads the IOS it will then immediately reboot.
Ill have full logs of whats going on below.
Originally the switch came with a IOS on it, In the console i can see it trying to load the IOS, then after it get done loading the IOS. The console and switch would just die after "uncompressed and installed, entry point"
Sometimes I would see entry point show "entry point 0x3000" but most of the time it doesn't even get to print that.
Just dies right before that happens.
So I have tried to fix it by putting a new IOS on it thinking it was a bad IOS. But having no luck fixing this
I have tried these steps in this order,
Boot in ROMmon,
Flash_init
Format flash:
boot usbflash0:/filename.bin
2 different IOS ver.
All of this work fine with no errors, until once again once it finish loading the IOS it dies and reboots.
im just not sure where to go now to fix this.
Thanks for the help
Logs:
https://pastebin.com/wYvE0HLg
please ignore the type errors in log. line 97 is the start of boot via usb
Leo Laohoo
Reboot the switch/stack by pulling the cable.
Obviously that did nothing.....
here is the recent crash log
https://pastebin.com/m2vNKKUq
