Why is wlan-ap 0 unable to shutdown on IR829
j.kwek
I am trying to shut down the wlan-ap 0 on IR829 but fail to do so.  The following are the result and message.  Pls advise.  Thanks.
version:
Version 15.6(3)M1b
Result of shutting down the wlan-ap 0
Router(config)#int wlan-ap 0
The wlan-ap 0 interface is used for managing the embedded AP.
Please use the "service-module wlan-ap 0 session" command to console into the embedded AP
Router(config-if)#shutdown
Router(config-if)#
*Jun 1 03:07:16.923: %WLAN_AP_INTF-6-NOCHANGE: Interface wlan-ap0, always stays up, to session into service-module
0 Replies 0
