2960X Switch - Console Authorization
Terry
Level 2
Level 2
I'm seeing an % Authorization failed error when I try to access my switch via the console port.
I want to separate my VTY and console access -
vty to use TACACS - this is working
console to use local database
I have the following config in place:
aaa new-model
aaa authentication login default group ISE local
aaa authentication login CONSOLE local
aaa authorization config-commands
aaa authorization exec default group ISE if-authenticated
aaa authorization commands 1 default group ISE if-authenticated
aaa authorization commands 15 default group ISE if-authenticated
aaa accounting delay-start
aaa accounting commands 1 default start-stop group ISE
aaa accounting commands 15 default start-stop group ISE
line con 0
 login authentication CONSOLE
My understanding is that there shouldn't be any authorization applied on the console port by default, but when I debug the switch (debug aaa authorization) I can see the default method is being picked. This is also the case when I configure authorization for the console port.
I have found some bugs for this issue but they all relate to older software versions, I can't find anything for the version I'm running:
WS-C2960X-48FPS-L (stack x2)
15.2(4)E7
cmarva
Level 8
Level 8
It's been a while, but I think you can do something like:
aaa authorization CONSOLE none
you may have to play around with syntax to find the right command.
