2960X SWITCH NOT BOOTING
kipbenard
Morning Team
i have an issue with 2960x switch,,the swicth kept on restarting and i decided to format flash and reinstall the ios,
after installing the ios it stills keeps on rebooting, check below info from console
File "tftp://192.168.0.10/c2960x-universalk9-mz.150-2a.EX5.bin" successfully cop
ied to "flash:c2960x-universalk9-mz.150-2a.EX5"
switch: boot
Loading "flash:/c2960x-universalk9-mz.150-2a.EX5/c2960x-universalk9-mz.150-2a.EX
5.bin"...mifs[9]: Invalid dir sctr=2
flash:/c2960x-universalk9-mz.150-2a.EX5/c2960x-universalk9-mz.150-2a.EX5.bin: no
such file or directory
Error loading "flash:/c2960x-universalk9-mz.150-2a.EX5/c2960x-universalk9-mz.150
-2a.EX5.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c2960x-universalk9-mz.150-2a.EX5"...Verifying image flash:/c2960
x-universalk9-mz.150-2a.EX5.....................................................
..................................................................Image passed d
igital signature verification
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 38:ed:18:69:e7:80
The password-recovery mechanism is enabled.
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 834560
mifs[5]: Bytes available : 971776
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 1 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 971264
mifs[6]: Bytes available : 2899456
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 6 files, 2 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 19658752
mifs[9]: Bytes available : 102526976
mifs[9]: mifs fsck took 21 seconds.
...done Initializing Flash.
-2a.EX5.bin"
Bernard
Leo Laohoo
Error message looks like the BIN file is corrupt.
Hi leo
so i try another IOS?
regards
Bernard
Try to download the firmware again & check the MD5 hash value against the MD5 hash value found in the Cisco website.
K@yT
Hi, Barnard!
Try to Load iOS in this format c2960x-universalk9-tar.150-2a.EX5.tar
