2x MS130-12X - Virtual Stack
hfaisca
Frequent Visitor
Frequent Visitor
I'm having some issues trying to create a virtual stack with two MS130-12X switches.
According to the Meraki documentation (Switch Stacks - Cisco Meraki Documentation), it mentions that virtual stacking is possible for the MS130 series.
However, when I follow the documented procedure, the option to create or manage a virtual stack does not appear in my Dashboard.
Could you please confirm if virtual stacking is actually supported on the MS130-12X model?
JamesT91
Meraki Community All-Star
Virtual stacking is just Meraki marketing terminology - there is no "stack" as such.
All it means is that you can manage and configure all switch ports within a single network easily from dashboard. The switches remain separate in terms of physical operation and network topology.
JamesT91
