3 x 3750X stackwise and stackpower cable connection
Kurt Lei
Level 2
Level 2
I have three 3750X switches needed to stacked with full bandwidth and redundancy. I am new in stacking switches. Do anyone can give me suggestion how the stackwise and stackpower cable connection ?
Is it practical on below connection for full bandswitch and redundancy ?
Stackwise
Switch 1 Stack 2 -- Switch 2 Stack 1
Switch 2 Stack 2 -- Switch 3 Stack 1
Switch 3 Stack 2 -- Switch 1 Stack 1
Stackpower
Switch 1 Bottom -- Switch 2 Upper
Switch 2 Bottom -- Switch 3 Upper
Switch 3 Bottom -- Switch 1 Upper.
Jose Solano
Level 9
Level 9
This looks good, the connections will have redundancy the way the you plan to do it. Below is a link that covers stack creation and questions:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html
Hope this helps, and remeber to rate any useful posts.
Jose Solano
Level 9
Level 9
Joseph W. Doherty
  • Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Actually cabling doesn't really matter, per se, although StackPower has an amperage limitation between stack members,  So power supplies should be placed to try to minimize Stack power draw, including when a power supply fails.
This whitepaper explains further: http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-x-series-switches/white_paper_c11-578931.html
