3064 RX input / CRC Error
In 3064 with QoS and VPC for server virtualization configuration, input and CRC errors appear as shown below.
Which one should I check?
NIC replacement and cable replacement are complete.
#show run
--omit----
policy-map type network-qos jumbo
class type network-qos class-default
mtu 9000
policy-map type network-qos vmware
mtu 9000
system qos
service-policy type network-qos jumbo
--omit----
interface Ethernet1/34
description = VS_S2_vSAN2=
switchport access vlan 101
speed 10000
duplex full
no negotiate auto
channel-group 1012
--omit----
#show int eth 1/34
Ethernet1/34 is up
admin state is up, Dedicated Interface
Belongs to Po1012
Hardware: 100/1000/10000 Ethernet, address: 78da.6e26.bf69 (bia 78da.6e26.bf69)
Description: = VS_S2_vSAN2=
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is access
full-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Auto-Negotiation is turned off FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
admin fec state is auto, oper fec state is off
Last link flapped 00:15:26
Last clearing of "show interface" counters 00:14:40
0 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 12408840 bits/sec, 385 packets/sec
30 seconds output rate 4542288 bits/sec, 363 packets/sec
input rate 12.41 Mbps, 385 pps; output rate 4.54 Mbps, 363 pps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 13100176 bits/sec, 353 packets/sec
300 seconds output rate 4655312 bits/sec, 327 packets/sec
input rate 13.10 Mbps, 353 pps; output rate 4.66 Mbps, 327 pps
RX
422249 unicast packets 36 multicast packets 4 broadcast packets
422289 input packets 1645230778 bytes
241735 jumbo packets 0 storm suppression packets
0 runts 0 giants 152 CRC 0 no buffer
160 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
400339 unicast packets 79 multicast packets 0 broadcast packets
400418 output packets 623572253 bytes
81597 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
GITJB_L3_2# show port-channel sum
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
b - BFD Session Wait
S - Switched R - Routed
U - Up (port-channel)
p - Up in delay-lacp mode (member)
M - Not in use. Min-links not met
Group Port- Type Protocol Member Ports
Channel
10 Po10(SU) Eth LACP Eth1/47(P) Eth1/48(P)
1001 Po1001(SU) Eth NONE Eth1/21(P)
1011 Po1011(SU) Eth NONE Eth1/33(P)
1012 Po1012(SU) Eth NONE Eth1/34(P)
1013 Po1013(SU) Eth NONE Eth1/35(P)
1014 Po1014(SU) Eth NONE Eth1/36(P)
1015 Po1015(SU) Eth NONE Eth1/37(P)
1016 Po1016(SU) Eth NONE Eth1/38(P)
GITJB_L3_2#show int status
---omit---
Eth1/34 = VS_S2_vSAN2= connected 101 full 10G 10Gbase-SR-S
Eth1/35 = VS_S3_vSAN2= connected 101 full 10G 10Gbase-SR-S
Jitendra Kumar
Have you checked the below things,?
because this is an L1 issue you need to check multiple things.
Please go through with the below discussion.
https://community.cisco.com/t5/switching/how-to-resolve-crc-errors/td-p/2216327
Jitendra
Jitendra
Hello
Check cabling, speed/duplex settings,
Kind Regards
Paul
Last link flapped 00:15:26<- link is flapping ??
why you config PO without LACP ??
mosharaflink
Hello All,
I am also facing same issue on my Nexus 3064 fiber sfp port and it is RX error and CRC issues. Steps I have taken but no luck.
Step1: Change cable
step2: change SFP
step3: change the physical port
Strange finding:
error generate on both switches in the RX section and TX is okay. I don't know how only errors generate on RX-RX rather than TX-RX
P2P Connectivity and port status:
R7-10G-SW2# sh interface eth1/48
Ethernet1/48 is up
Belongs to Po48
Hardware: 100/1000/10000 Ethernet, address: 1c6a.7a4c.d6d7 (bia 1c6a.7a4c.d6d7)
Description: **UL-R610G-SW2P44**
Port mode is trunk
Auto-Negotiation is turned off, FEC mode is Auto
EtherType is 0x8100
Last link flapped 20:24:12
Last clearing of "show interface" counters 17:33:01
0 interface resets
30 seconds input rate 32605832 bits/sec, 11024 packets/sec
30 seconds output rate 23405872 bits/sec, 2219 packets/sec
input rate 24.42 Mbps, 8.06 Kpps; output rate 25.10 Mbps, 1.97 Kpps
RX
172524118 unicast packets 307405 multicast packets 1018671 broadcast packets
173850194 input packets 83445699450 bytes
12770175 jumbo packets 0 storm suppression packets
0 runts 0 giants 345 CRC 0 no buffer
379 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 Rx pause
TX
82700440 unicast packets 4698 multicast packets 3188 broadcast packets
82708326 output packets 154246663374 bytes
23972295 jumbo packets
0 Tx pause
R6-10G-SW2# sh interface ethernet 1/44
Ethernet1/44 is up
Belongs to Po44
Hardware: 100/1000/10000 Ethernet, address: 6c41.6a62.e9d3 (bia 6c41.6a62.e9d3)
Description: ##R7-10G-SW2P48##
Port mode is trunk
EtherType is 0x8100
Last link flapped 20:24:40
Last clearing of "show interface" counters 10w6d
7 interface resets
30 seconds input rate 23716600 bits/sec, 2531 packets/sec
30 seconds output rate 30790224 bits/sec, 11371 packets/sec
input rate 24.36 Mbps, 1.93 Kpps; output rate 25.58 Mbps, 8.52 Kpps
RX
22111109799 unicast packets 594399 multicast packets 3774579 broadcast packets
22115478777 input packets 31149243228482 bytes
13894483251 jumbo packets 0 storm suppression packets
0 runts 0 giants 43686 CRC 0 no buffer
44510 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 input with dribble 140 input discard
0 Rx pause
TX
20541881997 unicast packets 36984405 multicast packets 106446177 broadcast packets
20685312579 output packets 11492146601215 bytes
4369234796 jumbo packets
0 lost carrier 0 no carrier 0 babble 15745 output discard
0 Tx pause
