3524 Switch won't go away
I have a core Cisco 4506 with several 4948  & 3020 switches and 1 OLD 3524 switch connected.
One of the 4948's is set to VTP master and the 4506 is set to client and all others are set to transparent.
When I turn off or disconnect the old 3524, a few hosts in just 1 vlan (5) become unreachable. All other hosts in that vlan are still reachable.
This is repeatable.
There is nothing connected to the 3524 other than a fiber trunk port.
I want to remove the 3524.. would setting ALL switches to transparent help?
Other suggestions?
Tim
8 Replies 8
Reza Sharifi
If the 3524 is already configured as transparent mode and no end device is connected to it, than removing it should not cause any issue.
I agree but that is not what is happening.. at least two hosts in one of the vlans become unreachable and come back when the 3524 is re-connected.
Are you sure there is no hosts connected to this switch and the VTP mode is transparent?
what is the output of sh vtp status?
Nothing connected except the trunk..
As you can see, the switch was configured quite a while ago.
3524-1-BackRoom#sh vtp stat
VTP Version                     : 2
Configuration Revision          : 0
Maximum VLANs supported locally : 254
Number of existing VLANs        : 18
VTP Operating Mode              : Transparent
VTP Domain Name                 : VWG
VTP Pruning Mode                : Enabled
VTP V2 Mode                     : Enabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0xA4 0xCD 0x09 0x3A 0xC7 0x00 0xF3 0xF9
Configuration last modified by 192.168.254.1 at 2-18-08 15:08:41
Do you see the MAC addresses for the 2 hosts that get disconnected?
sh mac address-table
is vlan 5 configured on this switch and is there any ports in this vlan?
sh vlan
Vlan 5 is not configured on any ports on this switch, CDP is off and vlan 5 does not show up in the table, maybe I should config. a port for vlan 5? It appears as lshut?
3524-1-BackRoom#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4,
                                                Fa0/11, Fa0/15, Gi0/1
2    Servers_Workstations             active    Fa0/16, Fa0/17, Fa0/22, Fa0/24
3    GUEST                            active
4    FMG                              active
5    LAB                              act/lshut
6    BACKUP                           active
7    DMZ                              active
8    TWC                              active
9    ATT                              active
10   LEGACY_204                       act/lshut Fa0/5, Fa0/6, Fa0/7, Fa0/8,
                                                Fa0/9, Fa0/10, Fa0/14, Fa0/18,
                                                Fa0/19, Fa0/20, Fa0/21
11   NEW_NET                          active
12   CQ-Phone                         active
13   Custom-Quest                     active    Fa0/12, Fa0/13, Fa0/23
14   VMotion                          active
1002 fddi-default                     active
1003 trcrf-default                    active
1004 fddinet-default                  active
1005 trbrf-default                    active
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
4    enet  100004     1500  -      -      -        -    -        0      0
5    enet  100005     1500  -      -      -        -    -        0      0
6    enet  100006     1500  -      -      -        -    -        0      0
7    enet  100007     1500  -      -      -        -    -        0      0
8    enet  100008     1500  -      -      -        -    -        0      0
9    enet  100009     1500  -      -      -        -    -        0      0
10   enet  100010     1500  -      -      -        -    -        0      0
11   enet  100011     1500  -      -      -        -    -        0      0
12   enet  100012     1500  -      -      -        -    -        0      0
13   enet  100013     1500  -      -      -        -    -        0      0
14   enet  100014     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 trcrf 101003     4472  1005   3276   -        -    srb      0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trbrf 101005     4472  -      -      15       ibm  -        0      0
VLAN AREHops STEHops Backup CRF
1003 7       7       off
3524-1-BackRoom#sh mac-address-table
Dynamic Address Count:                 171
Secure Address Count:                  0
Static Address (User-defined) Count:   0
System Self Address Count:             51
Total MAC addresses:                   222
Maximum MAC addresses:                 8192
Non-static Address Table:
Destination Address  Address Type  VLAN  Destination Port
0000.8594.88b2       Dynamic          2  GigabitEthernet0/2
0000.85b4.f8fb       Dynamic          2  GigabitEthernet0/2
0001.e62b.3ef3       Dynamic          2  GigabitEthernet0/2
0001.e67d.18b0       Dynamic          2  GigabitEthernet0/2
0001.e690.c922       Dynamic          2  GigabitEthernet0/2
0004.005a.c2e1       Dynamic          2  GigabitEthernet0/2
0006.5bb4.4d91       Dynamic          2  GigabitEthernet0/2
0006.f689.bf71       Dynamic         14  GigabitEthernet0/2
0006.f689.c1fb       Dynamic         14  GigabitEthernet0/2
0006.f689.c281       Dynamic         14  GigabitEthernet0/2
0006.f689.c296       Dynamic         14  GigabitEthernet0/2
0007.e947.a9ae       Dynamic          2  GigabitEthernet0/2
000b.cd29.0a7f       Dynamic          1  GigabitEthernet0/2
000c.2916.461c       Dynamic          2  GigabitEthernet0/2
000c.2917.1539       Dynamic          2  GigabitEthernet0/2
000c.2965.0f2f       Dynamic          8  GigabitEthernet0/2
000c.2977.cd4c       Dynamic          2  GigabitEthernet0/2
000c.298e.0734       Dynamic          2  GigabitEthernet0/2
0014.38cd.feb6       Dynamic          2  GigabitEthernet0/2
0014.6969.c5c0       Dynamic          1  GigabitEthernet0/2
0014.6969.c5c0       Dynamic          2  GigabitEthernet0/2
0014.6969.c5c0       Dynamic          3  GigabitEthernet0/2
0014.6969.c5c0       Dynamic          4  GigabitEthernet0/2
0014.6969.c5c0       Dynamic          6  GigabitEthernet0/2
0014.6969.c5c0       Dynamic          7  GigabitEthernet0/2
0014.6969.c5c0       Dynamic          8  GigabitEthernet0/2
0014.6969.c5c0       Dynamic          9  GigabitEthernet0/2
0014.6969.c5c0       Dynamic         11  GigabitEthernet0/2
0014.6969.c5c0       Dynamic         12  GigabitEthernet0/2
0014.6969.c5c0       Dynamic         13  GigabitEthernet0/2
0014.6969.c5c0       Dynamic         14  GigabitEthernet0/2
0014.6969.c5ff       Dynamic          1  GigabitEthernet0/2
0015.1765.3490       Dynamic          6  GigabitEthernet0/2
0016.767d.b37d       Dynamic          2  GigabitEthernet0/2
0017.6110.1247       Dynamic         12  GigabitEthernet0/2
0017.6110.1377       Dynamic         12  GigabitEthernet0/2
0017.6111.2415       Dynamic          2  GigabitEthernet0/2
0017.6111.2427       Dynamic          2  GigabitEthernet0/2
0017.f2d6.83ac       Dynamic          2  GigabitEthernet0/2
0017.f2d7.ab97       Dynamic          2  GigabitEthernet0/2
001a.a09b.5540       Dynamic          2  GigabitEthernet0/2
001b.549a.73bf       Dynamic          1  GigabitEthernet0/2
001b.549a.73bf       Dynamic          2  GigabitEthernet0/2
001b.549a.73bf       Dynamic         11  GigabitEthernet0/2
001b.549a.73bf       Dynamic         12  GigabitEthernet0/2
001b.639a.5e88       Dynamic          2  GigabitEthernet0/2
001b.7846.60f2       Dynamic          1  GigabitEthernet0/2
001b.7846.6502       Dynamic         11  GigabitEthernet0/2
001e.8fd2.c26a       Dynamic          2  GigabitEthernet0/2
001e.8fd8.d619       Dynamic          2  GigabitEthernet0/2
001e.c210.e70c       Dynamic          2  GigabitEthernet0/2
001e.c215.163e       Dynamic          2  GigabitEthernet0/2
001f.f3cb.0632       Dynamic          2  GigabitEthernet0/2
001f.f3d1.90c9       Dynamic          2  GigabitEthernet0/2
0021.5a92.4f7e       Dynamic         12  GigabitEthernet0/2
0021.7067.8ef7       Dynamic          2  GigabitEthernet0/2
0021.85fc.0cd7       Dynamic          2  GigabitEthernet0/2
0021.b70c.b543       Dynamic          2  GigabitEthernet0/2
0021.b714.c182       Dynamic         12  GigabitEthernet0/2
0021.b78c.79a6       Dynamic          2  GigabitEthernet0/2
0021.e9e0.8f0c       Dynamic          3  GigabitEthernet0/2
0022.4125.5991       Dynamic          2  GigabitEthernet0/2
0022.4138.c5fe       Dynamic          2  GigabitEthernet0/2
0023.3293.74b1       Dynamic          2  GigabitEthernet0/2
0023.3298.ca5a       Dynamic          2  GigabitEthernet0/2
0025.b3d5.29d3       Dynamic          2  GigabitEthernet0/2
0025.b3d5.2a0b       Dynamic          2  GigabitEthernet0/2
0025.b3d5.2ec4       Dynamic          2  GigabitEthernet0/2
0025.b3d5.30be       Dynamic         12  GigabitEthernet0/2
0025.b3d5.30ef       Dynamic          2  GigabitEthernet0/2
0026.2d16.fe26       Dynamic          2  GigabitEthernet0/2
0030.4882.6960       Dynamic          2  GigabitEthernet0/2
0030.4882.6994       Dynamic          2  GigabitEthernet0/2
0040.178f.0993       Dynamic         12  GigabitEthernet0/2
0040.178f.5a7c       Dynamic         12  GigabitEthernet0/2
0050.569d.0002       Dynamic         11  GigabitEthernet0/2
0050.569d.0007       Dynamic          2  GigabitEthernet0/2
0050.569d.0008       Dynamic         11  GigabitEthernet0/2
0050.569d.0501       Dynamic          4  GigabitEthernet0/2
0050.569d.1c3d       Dynamic          2  GigabitEthernet0/2
0050.569d.2365       Dynamic          2  GigabitEthernet0/2
0050.569d.236c       Dynamic          2  GigabitEthernet0/2
0050.569d.254c       Dynamic         11  GigabitEthernet0/2
0050.569d.26dd       Dynamic          2  GigabitEthernet0/2
0050.569d.26f8       Dynamic          2  GigabitEthernet0/2
0050.569d.2daa       Dynamic          2  GigabitEthernet0/2
0050.569d.2ffb       Dynamic          2  GigabitEthernet0/2
0050.569d.3d80       Dynamic          8  GigabitEthernet0/2
0050.569d.4feb       Dynamic         13  GigabitEthernet0/2
0050.569d.5267       Dynamic          2  GigabitEthernet0/2
0050.569d.527f       Dynamic          9  GigabitEthernet0/2
0050.569d.55a8       Dynamic         13  GigabitEthernet0/2
0050.569d.55ed       Dynamic          2  GigabitEthernet0/2
0050.569d.585b       Dynamic          2  GigabitEthernet0/2
0050.569d.5b09       Dynamic          2  GigabitEthernet0/2
0050.569d.613d       Dynamic         11  GigabitEthernet0/2
0050.569d.6839       Dynamic         11  GigabitEthernet0/2
0050.569d.685d       Dynamic         11  GigabitEthernet0/2
0050.569d.6de9       Dynamic          2  GigabitEthernet0/2
0050.569d.7a4d       Dynamic          2  GigabitEthernet0/2
0050.569d.7ac5       Dynamic          4  GigabitEthernet0/2
0050.737c.f822       Dynamic          8  GigabitEthernet0/2
0060.b0c7.498a       Dynamic         12  GigabitEthernet0/2
0080.64ab.a3f7       Dynamic          2  GigabitEthernet0/2
0080.64ac.06f1       Dynamic          2  GigabitEthernet0/2
0080.64ac.5999       Dynamic          2  GigabitEthernet0/2
0080.64b5.0a07       Dynamic          2  GigabitEthernet0/2
0080.9266.c6e2       Dynamic          2  GigabitEthernet0/2
00e0.c556.c68b       Dynamic          2  GigabitEthernet0/2
00e0.c558.3683       Dynamic          2  GigabitEthernet0/2
00e0.c55a.5c12       Dynamic          2  GigabitEthernet0/2
00e0.c55a.5dca       Dynamic         12  GigabitEthernet0/2
00e0.c55a.5eef       Dynamic          2  GigabitEthernet0/2
00e0.c55d.5846       Dynamic          2  GigabitEthernet0/2
00e0.c55e.7937       Dynamic         12  GigabitEthernet0/2
00e0.c55e.7af2       Dynamic          2  GigabitEthernet0/2
00e0.c55e.7ed2       Dynamic          2  GigabitEthernet0/2
00e0.c55e.e3de       Dynamic          2  GigabitEthernet0/2
0454.5311.aa0a       Dynamic          3  GigabitEthernet0/2
0800.09bd.d0a4       Dynamic         12  GigabitEthernet0/2
109a.ddc7.3591       Dynamic          3  GigabitEthernet0/2
20cf.30b6.31c0       Dynamic          2  GigabitEthernet0/2
3c07.5460.8783       Dynamic          2  GigabitEthernet0/2
3c07.5473.177b       Dynamic          2  GigabitEthernet0/2
406c.8f59.2584       Dynamic          2  GigabitEthernet0/2
4c8d.7943.afb0       Dynamic          2  GigabitEthernet0/2
5835.d998.99c4       Dynamic          1  GigabitEthernet0/2
5835.d998.f549       Dynamic          1  GigabitEthernet0/2
6427.370d.73ae       Dynamic          2  GigabitEthernet0/2
685b.35ad.69fc       Dynamic          2  GigabitEthernet0/2
685b.35b3.6ee7       Dynamic          2  GigabitEthernet0/2
685b.35ba.fd2d       Dynamic          2  GigabitEthernet0/2
685b.35c3.d91c       Dynamic          2  GigabitEthernet0/2
685b.35d1.8d0c       Dynamic          2  GigabitEthernet0/2
685b.35d3.5c1e       Dynamic          2  GigabitEthernet0/2
685b.35d3.9af3       Dynamic          2  GigabitEthernet0/2
689c.7063.e235       Dynamic          7  GigabitEthernet0/2
6c70.9f5b.7835       Dynamic          2  GigabitEthernet0/2
6cc2.1725.f865       Dynamic          2  GigabitEthernet0/2
74e5.0b16.f6d8       Dynamic          2  GigabitEthernet0/2
7845.c40c.539b       Dynamic          2  GigabitEthernet0/2
7845.c420.f6e8       Dynamic          2  GigabitEthernet0/2
7cad.74db.55c2       Dynamic         14  GigabitEthernet0/2
7cc3.a1b7.2ce9       Dynamic          3  GigabitEthernet0/2
80e6.50c3.b9b2       Dynamic          2  GigabitEthernet0/2
8478.acb3.4480       Dynamic         14  GigabitEthernet0/2
881f.a1de.f5e9       Dynamic         12  GigabitEthernet0/2
881f.a1e2.acd5       Dynamic         12  GigabitEthernet0/2
8c2d.aa4e.259f       Dynamic          3  GigabitEthernet0/2
904c.e582.c3ed       Dynamic          3  GigabitEthernet0/2
9c8e.99d7.dabf       Dynamic          2  GigabitEthernet0/2
a44c.1126.1778       Dynamic          3  GigabitEthernet0/2
a886.ddae.6e79       Dynamic          3  GigabitEthernet0/2
ac86.740f.4e4f       Dynamic         12  GigabitEthernet0/2
ac86.740f.4e57       Dynamic         12  GigabitEthernet0/2
ac86.740f.4e5f       Dynamic         12  GigabitEthernet0/2
ac86.740f.4e67       Dynamic         12  GigabitEthernet0/2
ac86.741c.061f       Dynamic         12  GigabitEthernet0/2
ac87.a303.3872       Dynamic          2  GigabitEthernet0/2
ac87.a307.a01d       Dynamic          2  GigabitEthernet0/2
b418.d1e9.ba67       Dynamic          3  GigabitEthernet0/2
b4b5.2fed.1ae8       Dynamic         11  GigabitEthernet0/2
bc16.65b4.e54f       Dynamic         14  GigabitEthernet0/2
c82a.142a.0a2d       Dynamic          2  GigabitEthernet0/2
c84c.7577.dd01       Dynamic         11  GigabitEthernet0/2
d48c.b5b5.2e21       Dynamic          9  GigabitEthernet0/2
d49a.20c0.e91c       Dynamic          2  GigabitEthernet0/2
d4ae.52c6.e270       Dynamic         11  GigabitEthernet0/2
d4f4.6fc0.ab9c       Dynamic          2  GigabitEthernet0/2
f4ce.4623.467f       Dynamic          2  GigabitEthernet0/2
Is the 3524 a nexus 3524?  Layer 3 switch?
No.. not a nexus.. just a very old layer 2 switch.
