3550 - 12T Speed Issue
edw
I have a Cisco 3550-12T and I have a few different machines plugged in for 1 gigabit connections. I seem to have a limit of 40MB/s to 45MB/s across machines. However the machines will run faster. For instance I plugged it into a dum Belkin 1Gigabit switch and got 65MB/s.
What could be causing this on the switch ?
Ed
17 Replies 17
timothy.a.brown
Hi Ed, can you post the following when connected to both?
sho run int xxx
sho interf xxx
sho interf xxx switchport
One thought is the port being set to desireable and changing between an access port and trunk port..., but would like to see the flow control.
Tim
show run int xxx
switchport access vlan 30
switchport trunk allowed vlan 31,32
switchport mode access
spanning-tree portfast
This looks a bit odd to me ??
Another port -
switchport trunk native vlan 31
One more -
show int xxx
  Hardware is Gigabit Ethernet, address is 000b.4627.a601 (bia 000b.4627.a601)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, link type is auto, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is off
  Last input never, output 2d20h, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     207220 packets input, 31668014 bytes, 0 no buffer
     Received 331 broadcasts (0 multicast)
     0 watchdog, 160 multicast, 0 pause input
     285548 packets output, 118403026 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Another one -
GigabitEthernet0/6 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 000b.4627.a606 (bia 000b.4627.a606)
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX
  Last input never, output 00:00:01, output hang never
     4843693 packets input, 1234446842 bytes, 0 no buffer
     Received 6858 broadcasts (0 multicast)
     0 watchdog, 1692 multicast, 0 pause input
     3119263 packets output, 2797420311 bytes, 0 underruns
Another one -
  Hardware is Gigabit Ethernet, address is 000b.4627.a607 (bia 000b.4627.a607)
  input flow-control is off, output flow-control is on
  Last input never, output 00:00:00, output hang never
  5 minute input rate 40000 bits/sec, 63 packets/sec
  5 minute output rate 1167000 bits/sec, 141 packets/sec
     1920008 packets input, 1909251251 bytes, 0 no buffer
     Received 1608 broadcasts (0 multicast)
     0 watchdog, 572 multicast, 0 pause input
     1840225 packets output, 1241616596 bytes, 0 underruns
show interface xxx switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 30 (test)
Trunking Native Mode VLAN: 31 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: 31,32
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Another one -
Switchport: Enabled
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Voice VLAN: none
Trunking VLANs Enabled: ALL
Protected: false
Another one -
Switchport: Enabled
Access Mode VLAN: 30 (Test)
Voice VLAN: none
Protected: false
Here is the conf with:
clock timezone GMT 0
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos
ip subnet-zero
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
switchport mode trunk
mls qos trust cos
macro description cisco-switch
auto qos voip trust
wrr-queue bandwidth 10 20 70 1
wrr-queue queue-limit 50 25 15 10
wrr-queue cos-map 1 0 1
wrr-queue cos-map 2 2 4
wrr-queue cos-map 3 3 6 7
wrr-queue cos-map 4 5
priority-queue out
spanning-tree link-type point-to-point
interface GigabitEthernet0/12
mls qos trust cos
auto qos voip trust
priority-queue out
interface Vlan1
ip address 192.168.1.2 255.255.255.0
ip default-gateway 192.168.1.1
ip classless
ip http server
ip http secure-server
control-plane
end
VLAN ID and IP addresses have been modified.
Thanks for any help
Ed
Just to clarify more. I have done some more checks and the data is going from port 4 to port 9 and using 30% of each port. Nothing is going out of the switch to the rest of the network ???? I have tried different NICs, hard drivers, servers, PC's etc - but still getting this annoying limit ??
Ed
Joseph W. Doherty
Disclaimer
The       Author of this posting offers the information  contained within   this     posting without consideration and with the  reader's   understanding   that   there's no implied or expressed suitability  or   fitness for any    purpose.  Information provided is for informational    purposes only  and   should not  be construed as rendering  professional   advice of any  kind.   Usage of  this posting's  information is solely  at  reader's own  risk.
Liability Disclaimer
In        no event shall Author be liable for any damages whatsoever      (including,   without limitation, damages for loss of use, data or      profit) arising  out  of the use or inability to use the posting's      information even if  Author  has been advised of the possibility of     such  damage.
Posting
You might be bumping against the performance capabilities of that switch.  It's documented as having 17 Mpps and a 24 Gbps fabric.
I would be gobsmacked if I'm hitting the max capcity. I only have two machines doing a copy. I would like to think I bought a gigabit switch not a 200Mbps
Thanks for any help
Ed
Disclaimer
Posting
Oops, sorry.  Numbers I posted last night are correct, but I slipped a decimal place calculating performance.  You should NOT be hitting the performance limitation of this switch.  For guaranteed wirespeed for 12 gig ports, you need a fabric of 24 Gbps, which it has, and 12 * 1.488 Mpps = 17.856, so its 17 Mpps is unlikely to be much of a performance limitation.
PS:
Not all switches, especially older models, guarantee wirespeed, but this particular switch should.
kapathak
Hi Ed,
Can you post the following outputs from two 'sample' ports where you see the limits in data transfer (ex port 4 and 9)
sh mls qos int gi0/x statistics
sh int gi0/x switchport
sh controllers ethernet-controller gi0/x
sh int gi0/x
sh sdm prefer
sh tcam
sh controllers uti
Kapil
Sorry for the late response - have put one port on here so far. Do you need more?
GigabitEthernet0/3
Ingress
  dscp: incoming   no_change  classified policed    dropped (in bytes)
Others: 0          0          0          0          0
Egress
Others: 0             n/a       n/a      0          0
WRED drop counts:
  qid  thresh1    thresh2   FreeQ
   1 : 0          0         1024
   2 : 0          0         1024
   3 : 0          0         1024
   4 : 0          0         1024
Switchport: Enabled
Access Mode VLAN: 32 (test)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Protected: false
  Transmit GigabitEthernet0/3        Receive
  51208485 Bytes                441486235 Bytes
3045453580 Unicast frames       207164621 Unicast frames
  94326554 Multicast frames       1565434 Multicast frames
  49164029 Broadcast frames         24318 Broadcast frames
         0 Discarded frames             0 No dest, unicast
         0 Too old frames               0 No dest, multicast
         0 Deferred frames              0 No dest, broadcast
         0  1 collision frames
         0  2 collision frames          0 FCS errors
         0  3 collision frames          0 Oversize frames
         0  4 collision frames          0 Undersize frames
         0  5 collision frames          0 Collision fragments
         0  6 collision frames
         0  7 collision frames 3463220317 Minimum size frames
         0  8 collision frames  161353604 65 to 127 byte frames
         0  9 collision frames  192756698 128 to 255 byte frames
         0 10 collision frames   42690056 256 to 511 byte frames
         0 11 collision frames   29910188 512 to 1023 byte frames
         0 12 collision frames  613790806 1024 to 1518 byte frames
         0 13 collision frames
         0 14 collision frames          0 Flooded frames
         0 15 collision frames          0 Overrun frames
         0 Excessive collisions         0 VLAN filtered frames
         0 Late collisions              0 Source routed frames
         0 Good (1 coll) frames         0 Valid oversize frames
         0 Good(>1 coll) frames         0 Pause frames
         0 Pause frames                 0 Symbol error frames
         0 VLAN discard frames          0 Invalid frames, too large
         0 Excess defer frames          0 Valid frames, too large
         0 Too large frames             0 Invalid frames, too small
514474297 64 byte frames               0 Valid frames, too small
336420337 127 byte frames
212496050 255 byte frames
100314481 511 byte frames
  40095141 1023 byte frames
1985234732 1518 byte frames
sh int gi0/x
GigabitEthernet0/3 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0011.92c1.4e83 (bia 0011.92c1.4e83)
     reliability 255/255, txload 76/255, rxload 1/255
  5 minute input rate 6640000 bits/sec, 12806 packets/sec
  5 minute output rate 301862000 bits/sec, 25535 packets/sec
     209283736 packets input, 475483503 bytes, 0 no buffer
     Received 1589755 broadcasts (0 multicast)
     0 watchdog, 1565437 multicast, 0 pause input
     3190001239 packets output, 1611818931 bytes, 0 underruns
sh sdm prefer
The current template is the default template.
The selected template optimizes the resources in
the switch to support this level of features for
16 routed interfaces and 1K VLANs.
number of unicast mac addresses:   6K
number of igmp groups:             6K
number of qos aces:                2K
number of security aces:           2K
number of unicast routes:          12K
number of multicast routes:        6K
sh tcam
sh controllers uti
Port       Receive Utilization  Transmit Utilization
Gi0/1              0                    0
Gi0/2              0                    0
Gi0/3              1                    66
Gi0/4              0                    0
Gi0/5              0                    0
Gi0/6              0                    0
Gi0/7              0                    0
Gi0/8              66                   1
Gi0/9              0                    0
Gi0/10             0                    0
Gi0/11             0                    0
Gi0/12             0                    0
Total Ports : 12
Switch Receive Bandwidth Percentage Utilization  : 3
Switch Transmit Bandwidth Percentage Utilization : 3
Switch Fabric Percentage Utilization : 3
Had a issue with show tcam as this command has loads of sub commands ??
Thanks for any help on this.
Ed
Anyone any ideas - what speeds are people seeing on these units when copying ?
Ed
Bump
nkarpysh
Hey,
So the main symptom we see is that 3750 giving 40 MB copy speed while other dummy switch (possibly hub) gives up to 60 MB. So far I don't see any drops on 3750 - it would definitely drop if were not able to pass through all it get on wire and we would see counters growing.
Can you please get these commands from ports in a copy path:
  • show queueing gi1/x
  • show int gi1/x switching   (this is hidden command so type exactyl this way)
Nik
HTH,
Niko
Yes thats correct - thou its a 3550 not a 3750 ?.... The other is a bum switch/hub not sure which.
GigabitEthernet0/3
          Throttle count          0
        Drops         RP          0         SP          0
  SPD Flushes       Fast          0        SSE          0
  SPD Aggress       Fast          0
SPD Priority     Inputs          0      Drops          0
     Protocol       Path    Pkts In   Chars In   Pkts Out  Chars Out
        Other    Process          0          0    3496688  209801344
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Spanning Tree    Process          0          0        283      16980
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
          CDP    Process          0          0     582934  224429590
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet0/9
          Throttle count          0
        Drops         RP          0         SP          0
  SPD Aggress       Fast          0
        Other    Process          0          0    3496340  209780464
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Spanning Tree    Process          0          0        312      18720
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
          CDP    Process          0          0     583035  224468475
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Interface GigabitEthernet0/3 queueing strategy: none
Interface GigabitEthernet0/9 queueing strategy: none
Ed
nkarpysh
Sorry my typo. Can you please also get these outputs:
show controller ethernet-controller port-asic statistics
show buffer
for further valid test we would need smth like IPERF SW installed on servers/PC to test the speed rates.
Nik
HTH,
Niko
Buffer elements:
     484 in free list (500 max allowed)
     826962652 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50, peak 68 @ 7w0d):
     50 in free list (20 min, 150 max allowed)
     413479850 hits, 6 misses, 18 trims, 18 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25, peak 118 @ 1w4d):
     23 in free list (10 min, 150 max allowed)
     81042 hits, 83 misses, 249 trims, 249 created
Big buffers, 1536 bytes (total 579, permanent 128, peak 579 @ 7w0d):
     164 in free list (128 min, 512 max allowed)
     1122391235 hits, 169 misses, 0 trims, 451 created
VeryBig buffers, 4520 bytes (total 0, permanent 0):
     0 in free list (0 min, 0 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 0, permanent 0):
Huge buffers, 18024 bytes (total 0, permanent 0):
Interface buffer pools:
Ram Access buffers, 1524 bytes (total 101, permanent 100, peak 187 @ 7w0d):
     101 in free list (100 min, 150 max allowed)
     251415544 hits, 141 misses, 5231 trims, 5232 created
CPU1 buffers, 1524 bytes (total 12, permanent 12):
     12 in free list (0 min, 12 max allowed)
     0 hits, 0 misses
CPU13 buffers, 1524 bytes (total 32, permanent 32):
     1 in free list (0 min, 32 max allowed)
     134 hits, 4 fallbacks
CPU11 buffers, 1524 bytes (total 32, permanent 32):
     16 in free list (0 min, 32 max allowed)
     25579 hits, 0 misses
CPU6 buffers, 1524 bytes (total 10, permanent 10):
     0 in free list (0 min, 10 max allowed)
     484153302 hits, 55293099 fallbacks
CPU12 buffers, 1524 bytes (total 20, permanent 20):
     10 in free list (0 min, 20 max allowed)
     10 hits, 0 misses
CPU3 buffers, 1524 bytes (total 20, permanent 20):
     10 hits, 0 misses
CPU0 buffers, 1524 bytes (total 200, permanent 200):
     200 in free list (0 min, 200 max allowed)
     0 hits, 0 misses
CPU5 buffers, 1524 bytes (total 200, permanent 200):
     0 hits, 0 misses
CPU8 buffers, 1524 bytes (total 32, permanent 32):
     16 hits, 0 misses
CPU4 buffers, 1524 bytes (total 450, permanent 450):
     224 in free list (0 min, 450 max allowed)
     92415626 hits, 0 misses
CPU2 buffers, 1524 bytes (total 10, permanent 10):
     1 in free list (0 min, 10 max allowed)
     460631095 hits, 46307790 fallbacks
CPU10 buffers, 1524 bytes (total 8, permanent 8):
     0 in free list (0 min, 8 max allowed)
     8 hits, 0 fallbacks
CPU9 buffers, 1524 bytes (total 32, permanent 32):
     16 hits, 0 misses
There is a lot of data for the asic - thou the above commnd doesnt exist.
We tried a tool for measuring bandwidth and speed but same results
Ed
