02-18-2012 06:48 PM - edited 03-07-2019 05:01 AM
Hey all,
I just got my 3550 delivered today and finished uploading the latest image.
I had a couple of complications with the install that might have generated this new issue. When I transferred the image via XModem, I changed the baud rate to 57600 for a quicker speed. Now that the image is installed and I can to the CLI, I found a troubling issue. (all dealing with a console connection)
When I boot into Rommon, I use a baud rate of 9600. When I load the IOS, I have to use 57600. The complication is that I have stated "set BAUD 9600" in rommon after "flash_init" and "load_helper". I have also tried "unset BAUD". After I set those parameters, I reboot and find that I need to use 57600 still. I have tried multiple variations of setting the baud rate back to its default. For instance, "set BAUD 9600" then "reset". "Set BAUD 9600" and unplugged the power cable. I tried not initializing the flash and changing it, but no luck.
I have copied out from the CLI. I start off in 9600 baud, and after the loader reaches a certain point, I get the weird text and have to change to 57600 baud to read the CLI. Example:
Cisco WS-C3550-24 (PowerPC) processor (revision D0) with 65526K/8192K bytes of m
emory.
Processor board ID CHK0628V0Y4
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:0A:41:E1:89:00
Motherboard assembly number: 73-5700-08
Power supply part number: 34-0966-02
Motherboard serial number: CAT06270E6S
Power supply serial number: LIT062700KB
Model revision number: D0
Motherboard revision number: C0
Model number: WS-C3550-24-SMI
System serial number: CHK0628V0Y4ÿþÿþÿþÿþÿþÿÿþÿþþþÿÿþþÿþÿþþþÿþþÿþþþþþÿþÿœA´%šÈìÈ
çËGJžöA”
x>÷ŽÞ^ÖÒ‚–+iq
Kão¶rž{[IKRÊ!ÀKÊ\œ¼ekÞa¦B”OK@Ù£†íŠiAÇKy¹ŽÛ†
{ÿœ
¨ÎIÚœ)a
äŸ\K4ÞD”
)äŸ\K4ÞD”
02-18-2012 06:55 PM
Is there a way to adjust the baud rate from the IOS CLI? I wouldn't care too much, but I have a terminal server connected to my devices and this makes it useless.
02-18-2012 09:17 PM
I found a resolution.
You can adjust the speed on the "line con [1]" using "speed [speed]". This seems like an artificial way to resolve the issue, but it works. GL to anyone else!
