3550 Switch Error
sahr
Community Member
I ordered a L3 Catalyst 3550 switch from ebay, plugged it in and was greated with these errors
IOS Version 12.1(14)EA1A
00:32:48: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 5: accessing failed
00:32:51: ***Err: I2C_do_transaction failed i2cRead: slave addr 0x20, addr 0x1 (ret 0x3007).
00:32:51: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 0: accessing failed
00:32:51: ***Err: I2C_do_transaction failed i2cRead: slave addr 0x25, addr 0x1 (ret 0x3006).
Does anyone know a solution to this?
Richard Burts
Both of the message posted are about power failures to 2 controllers on the switch. This suggests that there is some issue with the power supply on the switch. I don't know what it would take to repair this. Can you go back to whomever sold you the switch and complain?
Rick
Jitendra Kumar
3550-24 PWR interface receives an Electrostatic Discharge (ESD) from a device
https://bst.cisco.com/bugsearch/bug/CSCea40671
Issue the shutdown command, followed by the no shutdown command on the affected interfaces.
device should be places correctly.
upgrade your firmware version
Jitendra
Leo Laohoo
Post the complete output to the command "sh post".
