3550 switch POST failure
Marian Dolinsky
Frequent Visitor
Frequent Visitor
Hi All,
I have Cisco 3550 switch, on POST all lights flash amber very quickly and stay that way, nothing on the console....
Is it possible to fix it? Any ideas?
Marian
5 Replies 5
Leo Laohoo
Can you please post the full power up process?  It could mean a POST failure (you can't fix it) or the switch is in ROMmon (you CAN fix this).
It looks like total POST failure; I can’t get anything on the console. The leds go amber immediately after the switch is plug on and I can’t get to ROMMON.
LEDs going into amber could also mean the switch didn't boot properly.
probably you are right, that it is a boot problem, because when I left the switch powered on after about an hour or two later the amber leds went green, it booted up and looked fine. I formatted flash and put a new IOS some days ago (the old IOS was corrupted). Could that be a problem? Do you have any idea, why the switch needs so long time to boot up and how to fix it?
Switch#show boot
BOOT path-list:       flash:c3550-ipbase-mz.122-44.SE6.bin
Config file:          flash:/config.text
Private Config file:  flash:/private-config.text
Enable Break:         no
Manual Boot:          no
HELPER path-list:
NVRAM/Config file
buffer size:    393216
witch#show flash:
Directory of flash:/
    3  -rwx     6719872   Jan 1 1970 02:26:46 +00:00  c3550-ipbase-mz.122-44.SE6.bin
    4  -rwx          42   Jan 1 1970 00:04:06 +00:00  system_env_vars
    5  -rwx          69   Jan 1 1970 00:04:06 +00:00  env_vars
Switch#show post
Stored system POST messages:
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
POST: CPU Interface 2nd Stage Tests : End, Status Passed
POST: CAM Subsystem Tests : Begin
POST: CAM Subsystem Tests : End, Status Passed
POST: Ethernet Controller Tests : Begin
POST: Ethernet Controller Tests : End, Status Passed
POST: Loopback Tests : Begin
POST: Loopback Tests : End, Status Passed
Switch#show version
Cisco IOS Software, C3550 Software (C3550-IPBASE-M), Version 12.2(44)SE6, RELEAS
E SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 14:33 by gereddy
Image text-base: 0x00003000, data-base: 0x00D32668
ROM: Bootstrap program is C3550 boot loader
Switch uptime is 50 minutes
System image file is "flash:c3550-ipbase-mz.122-44.SE6.bin"
Cisco WS-C3550-48 (PowerPC) processor (revision H0) with 65526K/8192K bytes of m
emory.
Processor board ID CAT0715Y0ZP
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 4 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:0C:CE:29:87:00
Motherboard assembly number: 73-5701-08
Power supply part number: 34-0967-01
Motherboard serial number: CAT071502MW
Power supply serial number: LIT062800Q5
Model revision number: H0
Motherboard revision number: A0
Model number: WS-C3550-48-SMI
System serial number: CAT0715Y0ZP
Configuration register is 0x10F
Not sure.  If you have a POST failure during the bootup it could mean some failure.  If the POST failure comes-and-go it won't "go" for a long time and will come back permanently.
I haven't played with 3550 for a long time but I do know that some newer IOS for other models have microcode and bootstrap upgrades.  Both can take a long time to fully boot the appliance but it is just a one-off.  So try to boot your 3550 again and see if the bootup process is the same or quicker.
