3560 Crashed on Putting Dot1x Configuration
I have about 300 sites which are having more than 500 switches. I am in process to deploy Dot1x. I am configuring all the switches remotely one by one. While putting the configurations sometimes switch gets crash. This is all random. Like there is a possibility that one switch crashes on one site and one on another. I am using different IOS in different switches. I am unable to find out any exact bug which can hit under my environment.
One the switch come back after reload it gives below message in "show version"
System returned to ROM by bus error at PC 0x2AF251C, address 0x0
System restarted at 11:00:46 UAE Tue Mar 24 2015
System image file is "flash:/c3560-ipbasek9-mz.122-55.SE4.bin"
IOS : 12.2(55)SE5
IOS : 12.2(55)SE4
IOS : 12.2(35)SE5
interface FastEthernet0/x
 switchport access vlan 101
 switchport mode access
 switchport voice vlan 102
 ip access-group auth-default-acl in
 authentication event server dead action authorize vlan 101
 authentication host-mode multi-auth
 authentication order mab dot1x
 authentication priority dot1x mab
 authentication port-control auto
 mab
 dot1x pae authenticator
 dot1x timeout quiet-period 5
 dot1x timeout tx-period 5
 dot1x max-req 3
 dot1x max-reauth-req 3
 spanning-tree portfast
aaa group server tacacs+ SECURE
 server a.b.c.d
 server w.x.y.z
aaa authentication login CONSOLE local
aaa authentication login SECURE group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authentication dot1x default group radius
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization exec CONSOLE local
aaa authorization commands 15 NW group tacacs+ local none
aaa authorization network default group radius
aaa accounting dot1x default start-stop group radius
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa server radius dynamic-author
 client a.b.c.d server-key 7 <removed>
 client w.x.y.z server-key 7 <removed>
 port 3799
 auth-type all
radius-server attribute 44 extend-with-addr
radius-server attribute 8 include-in-access-req
radius-server dead-criteria time 3 tries 1
radius-server host a.b.c.d auth-port 1812 acct-port 1813
radius-server key 7 <removed>
radius-server vsa send accounting
radius-server vsa send authentication
12 Replies 12
Leo Laohoo
12.2(55)SE IOS didn't "mature" until 12.2(55)SE8.  So try to the latest version of 12.2(55)SE10.
Hi Leo,
Thanks for your reply. Your statement is based on experience but unfortunately I will not be able to simply state this to Customer. I would highly appreciate if you can share some document to prove this.
Thanks/Regards
If you want a list of known bugs and security vulnerabilities your fleet's IOS is running on, use Cisco Bug Toolkit.
Hi Leo,
Once again thanks for your reply. Can you check the below part taken from Crashinfo...Do u have any idea what it is stating ?
---- Partial decode of process block ----
Pid 306: Process "LLDP Protocol "
stack 0x46CCD5C  savedsp 0x3DC8B74
Flags: analyze prefers_new
Status     0x00000000 Orig_ra   0x00000000 Routine    0x00000000 Signal 0
Caller_pc  0x00000000 Callee_pc 0x00000000 Dbg_events 0x00000000 State  0
Totmalloc  513148     Totfree   110776     Totgetbuf  0
Totretbuf  0          Edisms    0x0        Eparm 0x0
Elapsed    0x1B0      Ncalls    0x878      Ngiveups 0x0
Priority_q 4          Ticks_5s  1          Cpu_5sec   0        Cpu_1min 11
Cpu_5min   1          Stacksize 0x2328     Lowstack 0x2328
Ttyptr     0x3DB27FC  Mem_holding 0x652C     Thrash_count 0
Wakeup_reasons      0x0FFFFFFF  Default_wakeup_reasons 0x0FFFFFFF
Direct_wakeup_major 0x00000000  Direct_wakeup_minor 0x00000000
Preempted processes context:
Post the crashinfo file.  I am not certain which of the crashinfo file you've opened up.
I still stand with my initial recommendation that the most stable IOS is still 12.2(55)SE10.
Dear Leo,
I am attaching crashinfo's of two different switches.
mez-sw7-crashinfo.txt is dated 12 March 2015.  The other cannot be determine how recent/old it is.
Yes, you are right these are around 3 weeks old. For the second one I am attaching the show tech-support which includes the Crashinfo also.
Crash is caused by an IOS bug.  Only Cisco can decipher what caused this bug.
Here is a bug that affects 12.2(55)SE5
CSCuc47072
Symptom:
3560 hangs and creates crash dump during dot1x authentication.
As a result the 3560 becomes in accessible via ssh or console.
Only recourse is to power cycle the switch
Conditions:
3560 running 12.2(55)SE5
RADIUS server is ISE 1.1.1
Workaround:
None
Hi Cehill,
Thanks for your response. Can you share the details of fixed IOS version of 3560 for this bug as when I am opening this bug it is not showing any IOS which Cisco built for 3560. I can see the bug is duplicated with another bug.
I am attaching two images for details.
Thanks/Regards
I attached a snapshot of the bug, unfortunately it shows no known fixed release.
I would follow Leos advice of 12.2(55)SE10.
