3560 Dropping packets
Amit Singh2000
Level 2
Level 2
Hello guys
    i need your help to find a way to see if my switch is dropping any packets  bigger than 1500 bytes..
The scenario is like this
Router>>>>>>Switch(3750)>>>>>Router
From router to router i can ping with  byte size of 1500.. Any packets bigger than 1501 get dropped.
On switch i have changed the MTU to 1546 .. Restarted ..Still no luck...
the switch inbetween is a 3750EMI switch but in this case just doing layer 2 switching.. No routing is enabled on the switch..
Is there any way i have see if switch is dropping the packets ? The switch is sitting in a DC..
System MTU size is 1546 bytes
System Jumbo MTU size is 1546 bytes
System Alternate MTU size is 1546 bytes
Routing MTU size is 1500 bytes
Thanks ..
Nagendra Kumar Nainar
Hi Amit,
What is the MTU size of the router interface?. From secription, Am I assuming right that the MTU is 1500?.
Are you trying ping test between routers with DF bit set?.
Nagendra
Hi Amit,
What router are you using and can you please advise if the connection between the 3750/3560 and router is Fast Eth or Gig eth? If its a fasteth , then you are limited to 1500bytes. But if its a GigE then you can manually change the MTU on the interface to support more than 1500.
Routers like 2610, 2801..they all have fasteth and hence are limited . So, even if you increase the MTU on the 3560 it doesnt make any diff as the limitation is with th router.
To test the end to end MTU between the routers use the df-bit.
I am pasting something here for you which will give you a good idea
R2#ping 10.1.1.1 size 1500  df-bit
Sending 5, 1500-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Packet sent with the DF bit set
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/50/72 ms
R2#ping 10.1.1.1 size 1501  df-bit
Sending 5, 1501-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/1)
R2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#int gi1/0           This is a  Gigeth hence can up the MTU >1500
R2(config-if)#mtu
R2(config-if)#mtu 1520
R2(config-if)#end
R2#
*Feb 21 15:19:46.195: %SYS-5-CONFIG_I: Configured from console by console
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/20/48 ms
R2#
R2#ping 10.1.1.1 size 1520  df-bit
Sending 5, 1520-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/41/64 ms
R2#ping 10.1.1.1 size 1521  df-bit             Since the MTU is only 1520 this will fail
Sending 5, 1521-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R2#
HTH,
Please rate if helpful
jkilleda
Level 6
Level 6
Hello Amitpal,
Is there a firewall configured in your network , if yes then check the fragmented packets setting.
