3560 IOS upgrade and PBR question
itadmin
I have a 3560, which is being used as our core router that I have recently installed. It still has the standard IOS which came with
(C3560E-UNIVERSALK9-M) it but I need to implement policy based routing so need to upgrade it and have downloaded c3560-ipservicesk9-mz.122-58.SE2.bin and indeally would like to install it in the morning before people start work.
I have 2 questions, 1, Is the ipservices capable of PBR as I have been reading conflicting reports, in fact my friend who works for Cisco has advised that it is not possible on the 3560.
2, When I do upgrade will there be any current configurations that are not compatible with the new one, I wouldnt image that there would be any but just wanted to make sure as it would be the biggest headache ever if it went wrong!!
Thanks in advance.
Jake
7 Replies 7
Hi Jake,
For your first question you can see:
https://supportforums.cisco.com/community/netpro/network-infrastructure/routing/blog/2011/03/31/pbr-on-switches-37503560
for the second you should send us what type of service you have implemented.
Hi Christos,
Thanks for the quick reply. Please see my sho run below
no aaa new-model
system mtu routing 1500
ip routing
ip dhcp excluded-address 10.10.11.0 10.10.11.199
ip dhcp excluded-address 10.10.200.0 10.10.200.219
ip dhcp excluded-address 192.168.100.0 192.168.100.50
ip dhcp pool VLAN-11
   network 10.10.11.0 255.255.255.0
   dns-server 8.8.8.8 8.8.4.4
   default-router 10.10.11.1
ip dhcp pool VLAN-200
   network 10.10.200.0 255.255.255.0
   default-router 10.10.200.1
ip dhcp pool VLAN-192
   network 192.168.100.0 255.255.255.0
   default-router 192.168.100.1
no ip domain-lookup
ip domain-name xxxx.xxxx
spanning-tree mode rapid-pvst
spanning-tree vlan 1-2,5,9-11,50,60,70,80,100,192,200 priority 24576
vlan access-map 192_block 10
action drop
match ip address Block_WiFi_from_Int
vlan internal allocation policy ascending
ip ssh version 2
class-map match-all llp_to_watchguard
match access-group 101
policy-map pm_llp_to_watchguard
class llp_to_watchguard
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1
description LINK TO BHM_C4L_SWI
switchport trunk allowed vlan 100
switchport mode trunk
interface GigabitEthernet0/2
switchport access vlan 50
switchport mode access
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
description link to netgear wireless
interface GigabitEthernet0/6
description Trunk to Server switch, rack 2
interface GigabitEthernet0/7
description Trunk to SW19 (floor 11)
interface GigabitEthernet0/8
description Trunk to SW20 (floor 11)
interface GigabitEthernet0/9
description Trunk to SW21 (floor 11)
interface GigabitEthernet0/10
description Trunk link to edge_poe_flr10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
description LINK FOR EXTERNAL CALLS
switchport access vlan 2
interface GigabitEthernet0/13
description LINK TO fmts_bhm_sw_edge_01 (flr 11)
interface GigabitEthernet0/14
description LINK TO fmts_bhm_sw_edge_02
interface GigabitEthernet0/15
description LINK TO fmts_bhm_edge_poe1
interface GigabitEthernet0/16
description LINK to fmts_bhm_c4l_swi
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
description link to LLP ASA 5510
no switchport
ip address X.X.X.X X.X.X.X
interface GigabitEthernet0/22
description LINK TO FMTS_BHM_VIDOPS
interface GigabitEthernet0/23
description link to LLP ASA/Watchguard
no switchport
interface GigabitEthernet0/24
description link to MTS Watchguard
no switchport
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
ip helper-address X.X.X.X
interface Vlan2
ip address 172.28.1.1 255.255.255.0
interface Vlan9
interface Vlan11
interface Vlan28
interface Vlan50
interface Vlan60
interface Vlan70
interface Vlan80
interface Vlan100
interface Vlan192
ip helper-address X.X.X.X X.X.X.X
interface Vlan200
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.3.1
ip route 10.10.3.0 255.255.255.252 10.10.3.1
ip route 10.10.8.0 255.255.255.0 10.10.3.1
ip route 10.10.10.0 255.255.255.0 10.10.3.1
ip route 10.15.0.0 255.255.0.0 10.10.3.5
ip route X.X.X.X X.X.X.X 10.10.3.5
ip route X.X.X.X X.X.X.X X.X.X.X
no ip http server
ip http secure-server
ip access-list standard Block_wifi_from_internal
deny   10.0.0.0 0.255.255.255
deny   172.20.2.0 0.0.0.255
deny   172.20.0.0 0.0.255.255
permit any
ip access-list extended ACL_LLP_SSL_ASA
deny   ip 10.0.0.0 0.255.255.255 10.10.0.0 0.0.255.255
permit ip 10.10.0.0 0.0.255.255 10.0.0.0 0.255.255.255
ip access-list extended ACL_LLP_SSL_Watch
ip access-list extended ACL_MTS_SSL_ASA
ip access-list extended ACL_NY_VPN
permit ip 10.10.0.0 0.0.255.255 10.15.0.0 0.0.255.255
ip access-list extended PERMIT_MTS_ENF
permit ip 10.10.32.0 0.0.15.255 10.100.0.0 0.0.255.255
permit ip 10.10.64.0 0.0.15.255 10.100.0.0 0.0.255.255
ip access-list extended acl-pbr
deny   ip 10.10.0.0 0.0.255.255 10.10.0.0 0.0.255.255
deny   ip 10.10.0.0 0.0.255.255 172.20.0.0 0.0.255.255
permit ip 10.10.0.0 0.0.255.255 any
access-list 10 deny   X.X.X.X X.X.X.X
access-list 10 permit any
access-list 101 permit ip X.X.X.X X.X.X.X host 0.0.0.0
access-list 101 deny   ip any any
access-list 150 remark LLP traffic to flow through old watchguard
route-map RM_ENF_VPN permit 10
match ip address PERMIT_MTS_ENF
set interface GigabitEthernet0/24
route-map LLP-Watchguard permit 10
match ip address 150
set ip next-hop X.X.X.X
route-map rm-pbr permit 10
match ip address acl-pbr
set ip default next-hop X.X.X.X
line con 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
Do you think that would be OK on the new ipservices IOS?
Thanks a lot
Jake
Hi Jake,
Send me also a sh ver from your router to see what IOS you have now.
Thanks for this Christos!
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
System image file is "flash:/c3560e-universalk9-mz.122-55.SE5/c3560e-universalk9-mz.122-55.SE5.bin"
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560X-24 (PowerPC405) processor (revision K0) with 262144K bytes of memory.
Processor board ID FDO1641P2AG
Last reset from power-on
12 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : AC:F2:C5:04:85:00
Motherboard assembly number     : 73-12554-08
Motherboard serial number       : FDO164120UU
Model revision number           : K0
Motherboard revision number     : A0
Model number                    : WS-C3560X-24T-S
Daughterboard assembly number   : 800-32786-02
Daughterboard serial number     : FDO16410SP3
System serial number            : FDO1641P2AG
Top Assembly Part Number        : 800-31331-07
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                : COMJU00ARD
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       12.2(55)SE5           C3560E-UNIVERSALK9-M
Configuration register is 0xF
I checked this IOS will be ok, no problem.
Thanks a lot for the Christos, as a matter of interest, where did you check the IOS?
Thanks again
Jake
Software advisor from cisco site
http://tools.cisco.com/Support/Fusion/FusionHome.do
