3560 mst vlan propagation
SpongeRob
Hi - I have installed a 3560 switch and trunked it to core switches via 10g uplinks. Prior to that I deleted the vlan.dat and configured the switch for respective vlans non of witch are connected yet.  My question is at what point in an MST config do the vlans propagate to the new switch?  No passwrod, domain matches, vtp 2, pruning.  I coonected a laptop assigning it to the vlan subnet for a port and can ping the core switches and see them via cdp.  Why isn't the vlan databse populated?
Thanks in advance -
Just found this from config guide on 6500 -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vtp.html#wp1052427
So if you are running SXH you should be able to see the password. Not sure what is going on here.
Jon
9 Replies 9
Jon Marshall
It's not really to do with STP. Assuming switches are interconnected with a L2 trunk, things to check -
1) if the sending switch (in terms of VTP advertisements) is VTP transparent it won't send update, although it would pass VTP update along
2) if receiving switch is VTP transparent it won't use update
3) if password is set must be the same
4) if domain is set on sending switch then it must either be -
i) unset on receiving switch, in which case it will use sending switches domain
ii) set to same as sending switch on receiving switch
5) VTP revision number must be higher on sending than receiving switch. Check rev numbers with "sh vtp status". If it's the same then modify the vlan database on sending switch.
Jon
Thanks Jon,
My first aquaintence with this organization, anyhow turns out they have a PW on the cores - how is the PW then encrypted/decrypted?
Unless it's vtp version 3 then you can't encrypt the password. However even if it sin't encrypted it is not sent over the wire as an MD5 hash is used at both ends.
So if it's v2 just do a "sh vtp status" on core switch and it will tell you what it is. If it v3 then as far as i am aware you need to know the password ie. it cannot be retrieved from the switch.
Jon
jon - l beg to differ sir;
this is a 6509 vtp v2, server, and the password when s vtp pass = VTP Encrypted Password: 984987e49874d9874c - whathe !
Hmm, maybe i am mistaken then.
What is your 6500 running ie. IOS or a combination of CatOS on switch and IOS on MSFC ?
Also what does "sh vtp status" show ?
Jon
Hi Jon,
IOS 12.2(33) sxh6
I ran into this trying to add another switch,3560, to the domain - UFB
vtp is just what I mentioned;
VTP Version: 2
Conf rev:102
max vlans:1005
existing:91
VTP mo:Server
VTP dom:our domain
VTP prun, v2,traps: enabled
MD5 digest:0xc2 0x80...
Sh vtp password
VTP Encrypted Password: 898179847...
You can try doing a more of the vlan.dat file ie. "more vlan.dat". There will be a lot of unintelligible characters but it may also show the VTP password.
Jon
Jon
Thanks again Jon - my suspicion is my predessor may have encrypted this in V3 and the regressed to V2 - I'm going to TAC it and I'll updated you if you wish ?  Best Regards,
