3560 not using new crypto key
Doug Engel
I have a 3560 running 12.2(25)SEE3 which has a 768 bit key.  We need to replace that key with a 1024 bit key.
After I create the new key, it appears that the switch does not use it.  Looging in with putty and looking at the (putty) log, I see the following:
2013-09-10 11:47:25    Host key fingerprint is:
2013-09-10 11:47:25    ssh-rsa 768 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
2013-09-10 11:47:25    Initialised AES-256 CBC client->server encryption
2013-09-10 11:47:25    Initialised HMAC-SHA1 client->server MAC algorithm
This is after I zerosized the key and then recreated it.
Thoughts
-Doug
Marvin Rhoads
Did you recreate using "crypto key generate rsa"?
You don't perhaps have a different heypair hardcoded do you? (e.g. "ip ssh keypair-name ___")
router#crypto key zeroize rsa
then
router#crypto key gen rsa gen mod 1024
It seemingly generates the key as it should, but does not seem to be using it for ssh connections.
router#sh run | i ssh
ip ssh version 2
transport input ssh
transport input ssh
I don't think I am able to set a specific keypair for ssh.
Hmmm.
If you try to ssh in anew after doing the zeroize but before regenerating is the connection accepted?
You do have an "ip domain-name" configured right? "crypto key gen rsa" should require it but I shouldn't assume...
Once I zerosize the "old" key out and before I create a new one, i am still able to ssh into the switch.
I do have an ip domain-name configured.
Wish I could reload with the new key and see if that resolves it.
