3560 Odd Power Issues
Douglas Oman
I have a 3560-24ps, and I'm having issues with it booting. When I power the device up all the front panel lights come on like normail, and then the system light starts flashing like normal, but after 5 - 6 seconds the system light goes off. I don't get any output from the console, and the fans still run. Anyone have any ideas?
Doug
5 Replies 5
Leo Laohoo
Can you please post the entire bootup process?
It doesn't even begin the boot process. When powered on the Led's all come on then the system light blinks for a few seconds then turns off. During this process I do not get any output on the console
Thanks!
Can you try other clients?
If you get no input from the console then RMA it .  You should get input from the console from the moment it is plugged in.
Douglas Oman
I didn't try other clients as it works on other devices. This switch was pulled from a production environment and shelved for a month Rand now nothing. I was hoping that it was something such as the psu. My employer gave me the switch since it was dead thus there is no smartnet to get the rma under.
Thanks!
