[Cisco 7606] redundancy upgrade issue
averyanov_ya
I try to upgrade Cisco 7606-s according to this instruction:
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/redund.html#wp1089399
After uploading new IOS and reload, second RSP720-3CXL-GE in 6 slot doesn't work. All LEDs are orange.
When I exec sh file system, I don't see slavesup-bootdisk:
Could you some advices to me about this problems?
[1]  sh ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 15.2(1)S1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 16-Feb-12 01:34 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRE, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 15.2(1)S1, RELEASE SOFTWARE (fc2)
7606_5 uptime is 6 hours, 7 minutes
Uptime for this control processor is 6 hours, 7 minutes
System returned to ROM by reload (SP by reload)
System image file is "sup-bootdisk:/c7600rsp72043-advipservicesk9-mz.152-1.S1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606-S (M8500) processor (revision 1.1) with 1900544K/131072K bytes of memory.
Processor board ID FOX1547G7YQ
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.1, (0x80390021)
CORE: E500, Version: 2.2, (0x80210022)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
[2] sh platform hardware capacity
System Resources
  PFC operating mode: PFC3CXL
  Supervisor redundancy mode: administratively sso, operationally sso
  Switching resources: Module   Part number               Series      CEF mode
                       4        WS-X6724-SFP              CEF720           CEF
                       5        RSP720-3CXL-GE        supervisor           CEF
                       6        RSP720-3CXL-GE        supervisor           CEF
Power Resources
  Power supply redundancy mode: administratively redundant
                                operationally redundant
  System power: 2669W, 0W (0%) inline, 986W (37%) total allocated
  Powered devices: 0 total, 0 Class3, 0 Class2, 0 Class1, 0 Class0, 0 Cisco
Flash/NVRAM Resources
  Usage: Module Device               Bytes:      Total          Used     %Used
         4      dfc#4-bootflash:              15990784             0        0%
         5  SP  sup-bootdisk:                512081920     354312192       69%
         5  SP  const_nvram:                    127212           556        1%
         5  SP  hidden-nvram:                  4059328         14008        1%
         5  RP  nvram:                         4059328         14008        1%
         5  RP  bootdisk:                    512081920             0        0%
CPU Resources
  CPU utilization: Module             5 seconds       1 minute       5 minutes
                   4                  11% /  0%            11%             11%
                   5  RP               2% /  1%             3%              3%
                   5  SP               3% /  0%             6%              5%
  Processor memory: Module   Bytes:       Total           Used           %Used
                    4                 182995472       61962888             34%
                    5  RP            1682043956      188292640             11%
                    5  SP             629718928      232663176             37%
  I/O memory: Module         Bytes:       Total           Used           %Used
              5  RP                   134217728       51101520             38%
              5  SP                    67108864       43819664             65%
EOBC Resources
  Module                     Packets/sec     Total packets     Dropped packets
  4          Rx:                      11            432416                   0
             Tx:                       7            144711                   0
  5  RP      Rx:                      14            316873                   0
             Tx:                      14            306688                   0
  5  SP      Rx:                      10            279653                   0
             Tx:                      16            423051                   0
VLAN Resources
  VLANs: 4094 total, 5 VTP, 0 extended, 26 internal, 4063 free
L2 Forwarding Resources
           MAC Table usage:   Module  Collisions  Total       Used       %Used
                              5                0  98304         17          1%
             VPN CAM usage:                       Total       Used       %Used
                                                    512          0          0%
L3 Forwarding Resources
Module              FIB TCAM usage:                     Total        Used     %Used
   5                     72 bits (IPv4, MPLS, EoM)      524288        2364      1%
                        144 bits (IP mcast, IPv6)      262144            9      1%
                     detail:      Protocol                    Used       %Used
                                  IPv4                         316          1%
                                  MPLS                        2048          1%
                                  EoM                            0          0%
                                  IPv6                           2          1%
                                  IPv4 mcast                     4          1%
                                  IPv6 mcast                     3          1%
            Adjacency usage:                     Total        Used       %Used
                                               1048576       12712          1%
     Forwarding engine load:
                     Module       pps   peak-pps                     peak-time
                     5           1491      13724  05:52:10 UTC Fri Mar 30 2012
Netflow Resources
          TCAM utilization:       Module       Created      Failed       %Used
                                  5              15490           0          5%
          ICAM utilization:       Module       Created      Failed       %Used
                                  5                  0           0          0%
                 Flowmasks:   Mask#   Type        Features
                        IPv4:     0   reserved    none
                        IPv4:     1   Intf FulNAT_INGRESS NAT_EGRESS FM_GUARDIAN
                        IPv4:     2   unused      none
                        IPv4:     3   reserved    none
                        IPv6:     0   reserved    none
                        IPv6:     1   unused      none
                        IPv6:     2   unused      none
                        IPv6:     3   reserved    none
CPU Rate Limiters Resources
             Rate limiters:       Total         Used      Reserved       %Used
                    Layer 3           9            6             1         67%
                    Layer 2           4            2             2         50%
ACL/QoS TCAM Resources
  Key: ACLent - ACL TCAM entries, ACLmsk - ACL TCAM masks, AND - ANDOR,
       QoSent - QoS TCAM entries, QOSmsk - QoS TCAM masks, OR - ORAND,
       Lbl-in - ingress label, Lbl-eg - egress label, LOUsrc - LOU source,
       LOUdst - LOU destination, ADJ - ACL adjacency
  Module ACLent ACLmsk QoSent QoSmsk Lbl-in Lbl-eg LOUsrc LOUdst  AND  OR  ADJ
  5          1%     2%     1%     1%     1%     1%     0%     0%   0%  0%   1%
L3 Multicast Resources
  Replication mode: Egress
  Replication capability: Module                                         Mode
                               4                                         Egress
                               5                                         Egress
  MET table Entries: Module                             Total    Used    %Used
                     5                                  32744       2       1%
QoS Policer Resources
  Aggregate policers: Module                      Total         Used     %Used
                      5                            1024            1        1%
  Microflow policer configurations: Module        Total         Used     %Used
                                    5                64            1        1%
Switch Fabric Resources
  Bus utilization: current: 0%, peak was 0% at 06:09:27 UTC Fri Mar 30 2012
  Fabric utilization:     Ingress                    Egress
    Module  Chanl  Speed  rate  peak                 rate  peak
    4       0        20G    0%    1% @05:42 30Mar12    0%    1% @06:09 30Mar12
    5       0        20G    0%    1% @06:09 30Mar12    0%    1% @05:51 30Mar12
  Switching mode: Module                                        Switching mode
                  4                                                    compact
                  5                                                    compact
Interface Resources
  Interface drops:
    Module    Total drops:    Tx            Rx      Highest drop port:  Tx  Rx
         no modules reported drops
  Interface buffer sizes:
    Module                            Bytes:     Tx buffer           Rx buffer
    4                                              1221120              152000
IBC Resources
  5  RP      Rx:                     169           4008231                   0
             Tx:                    2378          21942661                   0
  5  SP      Rx:                       6            158253                   0
             Tx:                      20            227919                   0
SPAN Resources
  Source sessions: 16 maximum, 0 used
    Type                                    Used
    Local                                      0
    RSPAN source (max   2)                     0
    ERSPAN source                              0
    Service module                             0
  Destination sessions: 64 maximum, 0 used
    Type                                    Used
    RSPAN destination                          0
    ERSPAN destination (max  24)               0
[3] sh file systems
File Systems:
       Size(b)       Free(b)      Type  Flags  Prefixes
             -             -    opaque     rw   system:
             -             -    opaque     rw   tmpsys:
             -             -    opaque     ro   flexwan-fpd:
             -             -      disk     rw   disk0:
             -             -      disk     rw   disk1:
*    512081920     157769728      disk     rw   sup-bootdisk:
     148556256             0    opaque     ro   sup-microcode:
             0     358437152    opaque     wo   sup-image:
        127212        126656     nvram     rw   const_nvram:
             -             -    opaque     rw   null:
             -             -    opaque     ro   tar:
             -             -   network     rw   tftp:
             -             -    opaque     wo   syslog:
       4059328       4045320     nvram     rw   nvram:
     512081920     512081920      disk     rw   bootdisk:#
             -             -   network     rw   rcp:
             -             -   network     rw   ftp:
             -             -   network     rw   http:
             -             -   network     rw   scp:
             -             -   network     rw   https:
             -             -    opaque     ro   cns:
      15990784      15990784     flash     rw   dfc#4-bootflash:
[4] sh module
Mod Ports Card Type                              Model              Serial No.
  4   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1548WT2L
  5    2  Route Switch Processor 720 (Active)    RSP720-3CXL-GE     SAL1550Y5FJ
  6    0  Supervisor-Other                       Unknown            Unknown
Mod MAC addresses                       Hw   Fw            Sw           Status
  4  649e.f30a.8168 to 649e.f30a.817f  5.1   12.2(18r)S    15.2(1)S     Ok
  5  2894.0fd0.e058 to 2894.0fd0.e05b  5.13  12.2(33r)SR   15.2(1)S     Ok
  6  0000.0000.0000 to 0000.0000.0000  0.0   Unknown       Unknown      Unknown
Mod  Sub-Module                  Model              Serial       Hw     Status
  4  Centralized Forwarding Card WS-F6700-CFC       SAL1549XAW6  4.1    Ok
  5  Policy Feature Card 3       7600-PFC3CXL       SAL1550Y3ZD  1.1    Ok
  5  C7600 MSFC4 Daughterboard   7600-MSFC4         SAL1550Y5Y5  4.0    Ok
Mod  Online Diag Status
  4  Pass
  5  Pass
  6  Not Applicable
robwils
It looks to me like it has not loaded any IOS. Connect to the console port of the 2nd Supervisor in slot 6 and make sure it is not stuck in ROMMON mode. If it is, then boot the same IOS as the active supervisor.
robwils
Thank you for answer!
Second supervisor fall in rommon with wrong BOOT variable.
