02-25-2014 10:13 PM - edited 03-07-2019 06:24 PM
hi all,
saw this POST on a WS-C3560C-8PC-S switch.
is this normal? i though status should all be passed.
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
extracting front_end/front_end_ucode_info (43 bytes)
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
02-26-2014 12:46 AM
Reboot the switch again and see if the same error message occurs. If it does, RMA the switch.
This is fine.
02-27-2014 12:45 AM
hi leo,
thanks for the feedback! this is a new switch actually.
was doing further reading and i saw it's a feature you can enable.
i believe and safe to say that this line during POST/boot up can be ignored.
