3560 Switch: dot1x auth-fail not available
jack
I have two switches running updated IOS's.  They are both 3560's.  On one of them the "dot1x auth-fail" setting is available on the other one it is not.
HERE IS SWITCH #1 :
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C3560-24PS      12.2(53)SE2           C3560-IPBASEK9-M
When I go to configure dot1x on an interface, here are the options I have:
SwitchA_3560_24_A#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
SwitchA_3560_24_A(config)# int f0/5
SwitchA_3560_24_A(config-if)#dot1x ?
  credentials     Credentials profile configuration
  default         Configure Dot1x with default values for this port
  max-reauth-req  Max No.of Reauthentication Attempts
  max-req         Max No.of Retries
  max-start       Max No. of EAPOL-Start requests
  pae             Set 802.1x interface pae type
  supplicant      Configure supplicant parameters
  timeout         Various Timeouts
As you can see, there is no "auth-fail" settings
HERE IS SWITCH #2 :
*    1 28    WS-C3560G-24PS     12.2(44)SE2           C3560-IPBASEK9-M
When I do to configre dot1x, here are the options:
SwitchB_3560GPWR_A#conf t
SwitchB_3560GPWR_A(config)#int g0/5
SwitchB_3560GPWR_A(config-if)#dot1x ?
  auth-fail          Configure Authentication Fail values for this port
  control-direction  Set the control-direction on the interface
  critical           Enable 802.1x Critical Authentication
  fallback           Enable the Webauth fallback mechanism
  guest-vlan         Configure Guest-vlan on this interface
  host-mode          Set the Host mode for 802.1x on this interface
  mac-auth-bypass    Enable MAC Auth Bypass
  port-control       set the port-control value
  reauthentication   Enable or Disable Reauthentication for this port
  violation-mode     Set the Security Violation mode on this interface
As you can see, "auth-fail" is the first setting and there are a lot more settings
Why do I have one set on one switch and another set on another switch?
One switch is a G switch while the other (with less options) is a FastEthernet switch.  Is this the difference?
Is there a way to activate the features I am missing without new hardware?
Thanks.
Peter Paluch
Jack,
The dot1x auth-fail seems to have been replaced by the following command:
authentication event fail retry N action authorize vlan X
where X is the number of the auth-fail (restricted) VLAN, and the N is a number you would use in the dot1x auth-fail max-attempts command, decreased by one. A configuration of the form
dot1x auth-fail vlan 999
dot1x auth-fail max-attempts 2
would be rewritten as
authentication event fail retry 1 action authorize vlan 999
Try this out.
Best regards,
Peter
Peter Paluch
Jack,
Try this out.
Best regards,
Peter
