3560 Transparent Mode: DHCP Problem
davidhuynh5
I'm just curious has anyone every had DHCP problem, when a switch is set to transparent mode? Once you set it to client mode it clears up?
glen.grant
Should not make any difference. Verify the vlans that are supposed to be there are still there when you change it transparent mode.
