3560 v1 & v2
dstehle
My customer  has asked if the 3560 v2 is backward compatible with the v1. They have V1s in the field but their spares are V2. Is there anything that would make these two switches incompatible?
David Stehle
mahmoodmkl
Level 7
Level 7
nothing as far as i know
Thank you,
David
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Cisco Catalyst 3560 v2 Series Highlights
• Lower power consumption than its predecessors
• Backward compatible - uses the same Cisco IOS® Software image as the 3560 series and has the same feature set
•  Full EnergyWise support to monitor energy consumption of network  infrastructure and implement energy saving programs to reduce energy  costs
• Compatible with Cisco Redundant Power System (RPS) 2300
• All units have a uniform depth of 11.9 inches for better cable management
• Preconfigurable with the Cisco IOS Software release at the time of ordering
• IPv6 routing included in the IP Services feature set
• DC powered stand-alone model
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/data_sheet_c78-530976.html
Thank you as well.
