3560 vlans configuration issue
Narsimha Golla
I have configured vlans in 3560G switch but vlans notable to accessing internet can anye  one check the attached configuration & plz do the need full
6 Replies 6
John Blakley
Which vlans are having a problem? When you have a host in a vlan, can it ping the vlan's svi?
HTH, John *** Please rate all useful posts ***
Thank's for replay
I create two vlans.  vlan10 & vlan20
Vlan10 hosts notable to communicating with vlan20 host's but Internet also not coming to both vlans hosts. but my requirement is vlans not communicate with each others & internet should  access both vlans hosts
Narsimha
Silling question to ask here, but does the host on vlan10 has a valid ip address/gateway/dns? Same for host in vlan 20?
Did you assign the IP addresses manually or expect those hosts to receive IPs from a DHCP server?  If those hosts are receving IPs from a DHCP server, under Interface Vlan 10, 20, add "ip helper-address IP_Address_Of_DHCP_Server"
Also, it's not a good idea that you post the switch config without masking or removing the switch local password.  I suggest you to change your switch password asap, and add this command "service password-encryption" to encrypt the password.
narasimha,
I am not able to open the config file as i use a mac and its an exe witin the zip file. so can u please send me the config as a txt file to inbox as a private message and i will look at it as well.
without looking at the config i can give you some pointers based on ur requirements.
1. First make sure you have ip routing enabled
2. If you dont want the vlans to talk to each other just configure ACL's
3. Make sure the default routing etc is properly configured
Kishore
Thanks, kishore plz check the attached configuration
Building configuration...
Current configuration : 5276 bytes
version 12.2
no service pad
hostname 12345
boot-start-marker
boot-end-marker
enable secret 5 $1$8CK6$UqhqMZhjUq4AsM1oJVf5S1
enable password
username cisco privilege 15 password 0
username admin privilege 15 password 0
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/12
switchport access vlan 20
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
switchport mode trunk
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
macro description cisco-switch
spanning-tree link-type point-to-point
interface GigabitEthernet0/22
interface GigabitEthernet0/23
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
interface GigabitEthernet0/24
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
ip address 192.168.2.50 255.255.255.0
interface Vlan10
ip address 192.168.10.1 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip default-gateway 192.168.2.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.1
ip http server
!control-plane
line con 0
line vty 0 4
password
login
length 0
line vty 5 15
login
end
can you ping 192.168.2.1??  As I mentioned you can use ACL's between the vlans to stop them talking to each other..
Now, i belive 192.168.2.1 is the ip on the router. You need to check if there is a return route to the vlans 10,20 on the router.
Kishore
