3560CG shows 0 traffic in class-map
dahua.huang
Hi, QoS expert
I tried to put QoS in a  WS-C3560CG-8TC-S  version 12.2(55)EX2.
It shows 0 traffic in class-map.
Here is the config
My question is why I can not see the traffic via class-map?
it should in the default Q if incorrect mark.
I erased the config and config with the autoQoS, shows the same result.
Let me know and thanks.
class-map match-any VoIP
  description Voice IP Phone RTP
match access-group 157
class-map match-any WEB
  description Internal Web, SSL Web, DNS query, Pinnacle
match access-group 153
policy-map QOSMARK
class VoIP
  set dscp ef
class WEB
  set dscp cs3
class class-default
  set dscp default
access-list 153 remark * WEB class (IP Precedence 2)
access-list 153 remark - HTTP traffic (within local only)
access-list 153 permit tcp any any eq www
access-list 153 permit tcp any eq www any
access-list 153 remark - SSL Web traffic
access-list 153 permit tcp any any eq 443
access-list 153 permit tcp any eq 443 any
access-list 157 remark * VoIP class (IP Precedence 5)
access-list 157 remark - voice RTP packets
access-list 157 permit udp any any range 16384 32767
access-list 157 permit udp any range 16384 32767 any
interface GigabitEthernet0/8
switchport access vlan 874
switchport mode access
service-policy input QOSMARK
here is the result
Switch#show policy-map interface g0/8
GigabitEthernet0/8
  Service-policy input: QOSMARK
    Class-map: VoIP (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group 157
        0 packets, 0 bytes
        5 minute rate 0 bps
    Class-map: WEB (match-any)
      0 packets, 0 bytes
      Match: access-group 153
        0 packets, 0 bytes
        5 minute rate 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
Switch#
Switch#show int g0/8
GigabitEthernet0/8 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is a456.3091.5488 (bia a456.3091.5488)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:03, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 5000 bits/sec, 7 packets/sec
     3111 packets input, 311714 bytes, 0 no buffer
     Received 91 broadcasts (79 multicasts)
     0 watchdog, 79 multicast, 0 pause input
     22156 packets output, 11306901 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Switch#
Hello Dahua, Adam,
Yes, it is a famous limitation regarding the "show policy-map interface" and documented by bug CSCso80701.
Just like Adam mentionned you can use 'show mls qos interface....[stat]' to get some infos instead.
CSCso80701
Symptom: "show policy-map interface"  shows no matches
Conditions:
This command is run on one of the following switches:
2950 / 2960 / 2970 / 3550 /3560 /3750
Workaround:
This is a hardware limitation and these switches do not support this output.  There is no workaround.
Best regards.
Karim
Aileron88
A lot of the time the 'sh policy map interface' command in a switching environment will simply show you what is applied to the interface. Try issuing a 'sh mls qos interface g0/8' or 'sh mls qos interface g0/8 stats'.
Adam
Hello Dahua, Adam,
CSCso80701
Conditions:
Workaround:
Best regards.
Karim
Thank you.
Very helpful.
