1841 setup problem, dhcp clients cannot see internet
stranm154
I'm trying to get a small branch office up and running. It has a newly installed T1 Line and a cisco 1841 router. The network is mixed topology with linux, mac and windows, no servers to speak of. We want to run dhcp and nat from the 1841 and seem to have hit a wall with this. The network connections are all good, the T1 is working and if I configure fastethernet 0/0 with an outside IP address and give clients static IP addresses things do work but we need to share an IP address. I've included the setup config from the router, any hints or help would be greatly appreciated since the clients can't connect to or ping the internet as soon as they try and use dhcp (though they do get valid dhcp ip addresses within the range specified).  The DHCP pool address is the valid external IP address that we want to use for all traffic going out from all the PC's hooked up through the switch (there is a dlink switch hooked to fastethernet 0/0).
Config:
smallmouth#show config
Using 1446 out of 196600 bytes
version 12.4
hostname smallmouth
boot-start-marker
boot-end-marker
enable secret 5 $1$4eEN$65vLCb8GnvRzQoOwZoT.K0
enable password XXXXXX
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool pool1
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 4.2.2.2
   lease infinite
archive
log config
  hidekeys
interface Tunnel1
no ip address
interface FastEthernet0/0
ip nat inside
ip nat enable
ip virtual-reassembly
speed 100
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 10.176.30.6 255.255.255.252
ip nat outside
ip nat enable
encapsulation ppp
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.176.30.5
no ip http server
no ip http secure-server
ip nat pool mypool 199.116.110.9 199.116.110.9 netmask 255.255.255.248
ip nat inside source list 7 pool mypool overload
access-list 7 permit 192.168.1.0 0.0.0.200
snmp-server community public RO
control-plane
line con 0
line aux 0
line vty 0 4
password XXXXXX
login
scheduler allocate 20000 1000
end
mikeburr1234
I think this might be your typo,
If you want all of the 192.168.1.0 to be NATd out the serial interface, then this hould be:
access-list 7 permit 192.168.1.0 0.0.0.255
Hope this helps.
Mike Burr
Mike's Technology and Finance Blog
mikeburr1234
Hope this helps.
Mike Burr
That was it... just a typo...but after hours of starring at documentation, the eyes, they get blurry.
Thanks Again for your help!!!
