3560cx vlan unassigned
Maxime4
Hi everybody.
I have a problem with the last update c3560cx-universalk9-mz.152-7.E4.bin. When I connect my switch on a link "trunk" I got unassigned vlan.
FYI : my configuration work with the previous version (c3560cx-universalk9-mz.152-6.E.bin)
switchport mode trunk
switchport nonegotiate
ipv6 traffic-filter DENY-IPV6 in
mls qos trust cos
dot1x pae supplicant
dot1x credentials switch_edge
dot1x supplicant eap profile switch_edge
ip dhcp snooping trust
Port Name Status Vlan Duplex Speed Type
Gi0/14 notconnect unassigned a-full a-1000 10/100/1000BaseTX
Someone know if it's a bug ?
cordially.
Maxime
Manoj Reddy
Hi, As per the output I can see that the port is Gi0/14 is not connected. Can you verify it once.
Also if possible please post sh cdp nei and sh run
Yes my port is connected.
When I run sh cdp nei nothing appear :
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
What do you want see on the sh run ?
Thx for your answer
