3560E-12D ?
jwarner
How many ASICs are in the version of the 3560E with 12 x 10G ports?
Are there 6 ASICs, two for each port?  How are they connected together inside the box?
Are these ASICs the same ones used in the rest of the 3650E products?
Thanks.
SunilKhanna
Level 5
Level 5
Check with command "show platform port-asic version" for the number ASICs. And "show platform pm if-numbers" for ASIC to port mapping.
Below is the output from C3560G-24TS switch
Switch#show platform port-asic version
Port-Asic Version Info:
ASIC-0: Version:1 DeviceType:0x2CA
ASIC-1: Version:1 DeviceType:0x2CA
ASIC-2: Version:1 DeviceType:0x2CA
ASIC-3: Version:1 DeviceType:0x2CA
ASIC-4: Version:8 DeviceType:0x2C1
ASIC-5: Version:1 DeviceType:0x2CA
ASIC-6: Version:1 DeviceType:0x2CA
Switch#show platform pm if-numbers
interface gid  gpn  lpn  port slot unit slun port-type lpn-idb gpn-idb
Gi0/1     1    1    1    1/3  1    1    1    local     Yes     Yes
Gi0/2     2    2    2    1/0  1    2    2    local     Yes     Yes
Gi0/3     3    3    3    1/1  1    3    3    local     Yes     Yes
Gi0/4     4    4    4    1/2  1    4    4    local     Yes     Yes
Gi0/5     5    5    5    0/2  1    5    5    local     Yes     Yes
Gi0/6     6    6    6    0/3  1    6    6    local     Yes     Yes
Gi0/7     7    7    7    0/0  1    7    7    local     Yes     Yes
Gi0/8     8    8    8    0/1  1    8    8    local     Yes     Yes
Gi0/9     9    9    9    3/3  1    9    9    local     Yes     Yes
Gi0/10    10   10   10   3/0  1    10   10   local     Yes     Yes
Gi0/11    11   11   11   3/1  1    11   11   local     Yes     Yes
Gi0/12    12   12   12   3/2  1    12   12   local     Yes     Yes
Gi0/13    13   13   13   2/2  1    13   13   local     Yes     Yes
Gi0/14    14   14   14   2/3  1    14   14   local     Yes     Yes
Gi0/15    15   15   15   2/0  1    15   15   local     Yes     Yes
Gi0/16    16   16   16   2/1  1    16   16   local     Yes     Yes
Gi0/17    17   17   17   6/3  1    17   17   local     Yes     Yes
Gi0/18    18   18   18   6/0  1    18   18   local     Yes     Yes
Gi0/19    19   19   19   6/1  1    19   19   local     Yes     Yes
--More--
Sunil
Pls rate the content if you find the posting useful.
Regards, Sunil Khanna
SunilKhanna
Level 5
Level 5
--More--
Sunil
