04-14-2011 05:15 AM - edited 03-06-2019 04:36 PM
folks
i have 3560e which doesn't appear to be passing igmp traffic to the upstream router
PC1 ----------- ASA ------------ PC2--------- 3560e ----------- 3825 -------------------- WAN --------------------- Router ------------- Server
My ASA runs SMR, has an igmp forward interface outside command on the inside and has a trunk port to the 3560e (Vlans 32 & 48)
PC2 is a test pc on the 3560e on vlan32
3825 is my ISPs router on vlan32
- if i try to access the stream from PC2 it works
- if i try to access the stream from PC1, i see the igmp join leave my ASA onto the 3560E (i've captured on the 3560e's link to the ASA)
i've also captured on the ASA and i can see the igmp packet leave the outside interface
but the join doesn't reach the 3825 (i've captured on the 3560e port facing the router and there is no join being forwarded)
the switch is running in layer 2, 12.2(35r)SE1
switch#sh ip igmp snooping querier
Vlan IP Address IGMP Version Port
switch#
Global IGMP Snooping configuration:
IGMP snooping : Enabled
IGMPv3 snooping (minimal) : Enabled
Report suppression : Enabled
TCN solicit query : Disabled
TCN flood query count : 2
Robustness variable : 2
Last member query count : 2
Last member query interval : 1000
anyone any ideas?
thanks to anyone taking the time to read this or to reply
04-14-2011 05:27 AM
folks
i've configured the command
ip igmp snooping vlan 32 mrouter int gi0/21
the ISP router is on gi0/21
the ASA is on gi0/7
switch#sh ip igmp snooping groups vlan 32
Vlan Group Type Version Port List
32 239.192.61.10 igmp v2 Gi0/7, Gi0/21
32 239.255.255.250 igmp v2 Gi0/7, Gi0/21
still no traffic hitting the asa external interface
04-12-2013 02:02 PM
hi, I'm a bit late here, but was researching IGMP on ASA and found this. offhand, it seems like there is a problem with the trunk link passing the IGMP join to the 3560. perhaps the 3560 doesn't process the JOIN and install the group address on the correct vlan?
If that doesnt work, try setting the pim RP value (3825 router address) in the ASA.
pim rp-address W.X.Y.Z
take a look at this link:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807631d2.shtml
