3560v2 specification
oongborirukkul
Community Member
I'm wondering about information that Cisco provide about 3560v2. I've just tried to find the specification of RAM for 3560v2 but nothing found. I just saw only compact flash 32MB why? Isn't 3560v2 need RAM? I don't think so. (grin) and one more question, is Forwarding bandwidth and switching fabric has the same meaning?
Please help me..
I knew, these are silly questions but I really didn't found these information.
Thank you in advance
8 Replies 8
Yudong Wu
Level 11
Level 11
You are right. Not sure why RAM info is missed in Data Sheet. It should be 128M, the same as previous 3560.
Here is a Q&A link.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/qa_c67-527785.html
Forwarding bandwidth is the capacity of switching fabric, which is 32Gbps.
Thank for your opinion.
Leo Laohoo
Memory is 32 mb and not compact flash.
Hi, leolaohoo
In my option, it is compact flash that use to store IOS or configuration file it's not memory that use to run running-configuration. What do you think?
I can not find any reference on Cisco website that the 3560v2 uses a Compact Flash memory as a storage. It uses a flash alright, but it does not seem to use the Compact Flash modules as the ISR routers do.
Best regards,
Peter
Hello, I found "sh ver" for 3560v2 in other conversation
"(revision C0) with 122880K/8184K bytes of memory."
that means 3560v2 approximate 128MB of RAM, right?
Anyone can confirm me? ( the link below as my reference)
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&topicID=.ee71a04&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd46f80
Yes, its RAM is 128M based on above show ver
Thank you for confirmation.
How could I find document that mention about RAM for 3560v2 model ?
It's so strange that Cisco try to hide this information. I don't understand.
