3560X how to use trial license?
mario_kmc
Hi everyone.
We just got brand new 3560X with LANBASE license installed. Wanted to confirm with a "show license"
To my surprice (output below) I hav IP Services evaluation. I tried to test with an "show ip route" and "ip route..." in configuration mode with no success. How do I use the trial license?
Switch#show license
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: 0  minute  0  second
Index 3 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
6 Replies 6
egemen1981
you can use the license boot level command to enable the temporary license and accept the end-user license agreement (EULA) in configuration mode.
Additional info
Temporary License: - A temporary software license is limited to a usage period (around 60 days). After the usage period expires, the  switch continues to use the temporary software license until it is restarted. Before it restarts, warning messages state the switch is running the feature set without a valid license. After the switch restarts, the switch uses a valid software license based on the hierarchy (ipservices>ipbase>lanbase). If the switch does not have a valid license, it uses the IP base software license.
Switch#show license Index 1 Feature: ipservices
Period left: 8  weeks 4  days    <<<<<<< Limited usage period
License Count: Non-Counted Index 2 Feature: ipbase
License Count: Non-Counted Here is the link that you could use to request for a temporary license: https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet?DemoKeys=Y Note: On this link you should give the correct UDI of the switch (use "show license udi")
I can use the license boot command to boot on the ios. But the switch does not give me an option to accept the EULA.
The command " license accept end user agreement " is not available.
How will I activate my license.
It says "active, not in use, EULA not accepted.
Verghese George
Mark,
I can use a license boot command for ip services. My issue is that I have no option available to accept EULA. The status is shown as "Active, Not in use, EULA not accepted". How do I enable ip services and also accept EULA?
screen shot of show licensescreen shot of show license
Verghese George
try command
if it takes you may need to save and reload it
Hi, did you manage to enable the evaluation license? Same problem here
