3560x Switch issues
why9chars
I have a 3560x switch and need to configure it as a dumb switch basically.
I have added VLan2 with an IP address.
shutdown Vlan1
Configured several ports to use Vlan2 and turned on Spanning-tree Portfast.
There are 3 servers plugged into this switch. They can all ping the switch and switch can ping them, however, they cannot ping each other.
Any thoughts?
check the firewall on the servers.
12 Replies 12
Reza Sharifi
Can you post "sh run" and point out what ports are connected to the servers?
I am working on that. I was working remotely and got kicked off before I could get the config copied.
Ports 3, 7 and 9 are the ones I have connected to servers.
Current configuration : 2822 bytes
version 12.2
no service pad
hostname dtam-test
boot-start-marker
boot-end-marker
enable secret 5 $1$O7jT$.9UWWhPZtYH4LaRpjooyc/
enable password admin
no aaa new-model
system mtu routing 1500
ip host-routing
no ip gratuitous-arps
no ip domain-lookup
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
switchport access vlan 2
switchport mode access
speed 1000
spanning-tree portfast
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
speed 1000
interface GigabitEthernet0/8
interface GigabitEthernet0/9
speed 1000
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 144.201.205.60 255.255.255.224
ip default-gateway 144.201.205.62
ip http server
no ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
password admin
login
line vty 5 15
password admin
login
end
The config looks good.  Can you also provide "sh vlan" output?
Also, this shouldn't matter, but can you turn on IP routing and test again?
VLAN Name                             Status    Ports
1    default                          active    Gi0/1, Gi0/2, Gi0/4, Gi0/5
                                                Gi0/6, Gi0/8, Gi0/10, Gi0/11
                                                Gi0/12, Gi0/13, Gi0/14, Gi0/15
                                                Gi0/16, Gi0/17, Gi0/18, Gi0/19
                                                Gi0/20, Gi0/21, Gi0/22, Gi0/23
                                                Gi0/24, Gi0/25, Gi0/26, Gi0/27
                                                Gi0/28, Gi0/29, Gi0/30, Gi0/31
                                                Gi0/32, Gi0/33, Gi0/34, Gi0/35
                                                Gi0/36, Gi0/37, Gi0/38, Gi0/39
                                                Gi0/40, Gi0/41, Gi0/42, Gi0/43
                                                Gi0/44, Gi0/45, Gi0/46, Gi0/47
                                                Gi0/48
2    VLAN0002                         active    Gi0/3, Gi0/7, Gi0/9
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
Get rid of the line "speed 1000" as you could run into trouble with auto-negotiation and MDI/MDI-X.
I removed the speed, still the same, i set the speed thinking maybe there was an Auto-negotiation issue.
Just asked them to do that.
what vtp mode are you in?  I didn't see vlan 2 in your show run..
VTP = server
interface Vlan1
no ip address
shutdown
interface Vlan2
Windows firewall?
