3560X Web GUI slow and not responding
xxh42197
I am relatively new to this project and trying to set up a used C3560X-24p-l. I managed to basic configure the switch with the CLI but would like to check out the web guy. Started the server with the ip http commands and it's even responding somehow in the browser. but too slow to actually be able to do something. I can log in, chrome then stops loading, Firefox is starting to load the GUI but very slowly and one moment times out.
The switch is reset, there is no extra configuration just IP address, gateway and telnet. It works fine so far.
It's using the (latest) firmware 15.2(4)E10, compiled 31-mar-20 by prod_rel_team. Also restartet the http server, rebootet the switch, nothing works.
Can anybody help?
thanks!
HX
Leo Laohoo
The GUI is there but nobody configures Catalyst switches using GUI because the GUI can only do a fraction of what anyone can do in CLI.  And configuring in CLI is way faster than GUI.
Hi @xxh42197
A few things you can try is:
 Try different browsers. I would try with InternetExplorer but an old version, the oldest you can get.
Take a look on the Java config. Slow down any security config
Use the incognito mode on the web browser.
 Dont expect fast response from this switch on web interface at all.
im2x4
I can use Firefox to open the 3750's WebUI and display it completely. Although the response is slow, it can be used normally, but there are not many settings that can be set.
Firefox version is 124.0.2 (64-bit).
