3650 IOS code
cmazur
I have just received a variety of 3650 switches (24 port, 48 port, POE, Non-POE).
Is there any differences between the IOS for the different varieties?
As far as I know there is no difference in the IOS Code. 3650s are running IOS XE.
Do not forget to activate the license to use different features:
license right-to-use activate ipbase all acceptEULA
(if you have ipservices, replace ipbase with ipservices). The default is lanbase.
HTH,
Meheretab
HTH,
Meheretab
