3650 priority level command with kilo bits per second
lkadlik
Level 4
Level 4
When I put the following policy map on my 3650 it appears to take the config but when I go back and look at it the kilo bits per second value assigned does not show in the config.  How can I verify that it is set appropriately?
The config I have dropped in is as follows:
policy-map pmap-10G-out
 class voice
  priority level 1 4096
 class video
  priority level 2 50000
I am using a lan base license with the bundle for cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin
Thank you.
Reza Sharifi
Try this command:
sh policy-map pmap-10G-out
Unfortunately it does not show it there either.  I am concerned even though I did not get an error when it went it the configuration file did not really take. I want to confirm the bandwidth I set in the policy map that was put in will be what is used.
  Policy Map pmap-10G-out
    Class voice
      priority level 1
    Class video
      priority level 2
The config I did was on a 3850 with IP Base license.  Yours is a 3650 with LAN based license.
So, they could be different.
lkadlik
Level 4
Level 4
Here is some additional output from the switch:
sh platform qos advanced qsb gigabitEthernet 1/0/1
QoS Subblock contents...iif_id: 0xc8884000000009 iif_type:146
def_cos = 0, def_cos_enable = 0, def_qos_label = 0
def_priority = 13, trust_enabled = 1
input_trans_index = 0, output_trans_index = 0
def_queuing = 0, trust_type = TRUST_DSCP
Failed to get IN client LE ifm_rc:1
Failed to get OUT client LE ifm_rc:1
policy_trust = TRUST_NONE
input_policy = (nil), output_policy = 0x540836c0 label_value = (nil)
afd_tgt_hdl = (nil), port type = Wired port, shape_rate = 0
afd_status = UNALLOCATED
num_radios 0
in_ag_1r2c_plc = 0, in_ag_2r3c_plc = 0
out_ag_1r2c_plc = 0, out_ag_2r3c_plc = 0
in_mf_plc = 0, out_mf_plc = 0
in_plc_map_index = -1
out_plc_map_index = -1
[ag_plc_handle = 0]
[mf_plc_handle in,out=(nil),(nil) num:0,0 base:-1,-1 rc:0,0]
afd_data.max = 0, afd_data.weight = 0
afd_rt1:police_en 0, rate 0, burst 0
afd_rt2:police_en 0, rate 0, burst 0
afd_client_max_rate = 0
sh platform qos policies port
Loc Interface          IIF-ID             Dir Policy             State
L:0 Te1/1/3            0x00c97b0000000072 OUT pmap-10G-out       INSTALLED IN HW
L:1 Gi1/0/1            0x00c8884000000009 OUT pmap-10G-out       INSTALLED IN HW
 qos policy target gigabitEthernet 1/0/1
Input policy :
         Not attached
Output policy :
POLICY: pmap-10G-out Tkn:260 Num Classes:3 PLC Map Targets:0 Queue LBL Targets uplink:1 downlink:1
VMRINFO: {
} VMRINFO
  PMAP:0x540836c0 Tkn:260 NextPMAP:(nil) PrevPMAP:(nil)
  num_classmaps 3 nfl_req_pending_cnt:0 pmap_qsize:0
  Stats debug counter: 0
    CLASS: voice Tkn:263
      CMAP:0x54086f28 Tkn:263 Next:0x540867f0 Prev:(nil)
      Masks:- UP:0, CoS: 0, Dscp:71468255805440
      Filter flags 0x2
      Match DSCP:40 46
      Negate: NO Next:(nil)
    CLASS: video Tkn:262
      CMAP:0x540867f0 Tkn:262 Next:0x54086110 Prev:0x54086f28
      Masks:- UP:0, CoS: 0, Dscp:85899345920
      Filter flags 0x2
      Match DSCP:34 36
    CLASS: class-default Tkn:261
      CMAP:0x54086110 Tkn:261 Next:(nil) Prev:0x540867f0
      Masks:- UP:0, CoS: 0, Dscp:0
      Filter flags 0
      Not Supported
  L:1 Target:Gi1/0/1 Tkn:264 DIR:OUT STATE:SET IN HW LE_LABEL:0, client_policy_type:LE nfl_pend:0
    IF:0x00c8884000000009 TCCGs:3 TCG:0x54087698 Tkn:264 Next:(nil) Prev:0x54088570
    TCG Stats debug counter: 0 vcu_cmhandle:0xffffffff  vcu_cmhandle:0xffffffff  vcu_cmhandle:0xffffffff
    CLASS: voice Tccg-Tkn:268
      Action flags:0x10
      TCCG Stats debug counter: 0
      Action:QUEUE Shared action obj token:258
      Queue Action
      Buffer ratio:0 Limit Type:Queue Limit Single
    CLASS: video Tccg-Tkn:267
      Action flags:0x10
      Action:QUEUE Shared action obj token:259
      Queue Action
    CLASS: class-default Tccg-Tkn:266
      Action flags:0x10
      Action:QUEUE Shared action obj token:257
      Queue Action
  Hardware States ****************
Additional details for policy: pmap-10G-out
        Number of targets attached to : 2
        Number of targets policy successfully programmed in HW: 2
sh platform qos policy name pmap-10G-out detail
VMRINFO: {
} VMRINFO
      Filter flags 0x2
      Match DSCP:40 46
      Filter flags 0x2
      Match DSCP:34 36
      Filter flags 0
      Not Supported
  L:0 Target:Te1/1/3 Tkn:269 DIR:OUT STATE:SET IN HW LE_LABEL:0, client_policy_type:LE nfl_pend:0
    IF:0x00c97b0000000072 TCCGs:3 TCG:0x54088570 Tkn:269 Next:0x54087698 Prev:(nil)
    CLASS: voice Tccg-Tkn:273
      Action flags:0x10
      Action:QUEUE Shared action obj token:276
      Queue Action
    CLASS: video Tccg-Tkn:272
      Action flags:0x10
      Action:QUEUE Shared action obj token:277
      Queue Action
    CLASS: class-default Tccg-Tkn:271
      Action flags:0x10
      Action:QUEUE Shared action obj token:275
      Queue Action
      Action flags:0x10
      Queue Action
      Action flags:0x10
      Queue Action
      Action flags:0x10
      Queue Action
unknown
