3650 Switch: Power Supply A not visible in Solarwinds
cisco_architect
I have a stack of 5 x 3650 switches with dual power supplies, however only one PS is visible in Solarwinds, namely "Power Supply B".  Can anyone advise why "Power Supply A" does not show?  On the switch both power supplies are showing in "show inventory".  The fan and temperature sensors all show up fine in Solarwinds.
Many thanks
jonathanlunt
I would try using a bash console and SNMP walking your device for the PSU module MIB (use the Cisco MIB identifier to double check). That way you can see if it is a device issue or Solarwinds.
That should be Bash Shell, not console... My bad. Cygwin is what I use at my work
Thanks for your reply Jonathon, much appreciated.
I've installed Cygwin but I'm having issues installing Net-SNMP from the command line.  Before I spend more time on this, are there any alternatives to checking the SNMP traffic from the switch?  I did a 'show snmp mib' on the switch but didn't see anything relating to PSU.
I've completed a MIB Walk of the 3650 switches. Can anyone confirm the exact MIB I need to check for the power supplies?
