3750 - 12.2(25) or 12.2(35)
aLTeReGo
I've noticed that IOS version 12.2(35) has been poping on and off the early release list for the 3750. Does anyone know what the major differences between 12.2(25)SEB4 and 12.2(35)SE2?? Why would I choose one over the other?
8 Replies 8
ahmednaas
Level 4
Level 4
good luck with that..
that utility is so messed up..
it doesn't even show me 12.2.35 se2
I even opened a tac call with a screen shot of the 3550 drill down showing me 2960 code and the tac engineer was going.. " I don't see the problem"
I gave up on tac, the guy was absolutely clueless... if someone from Cisco actually wants to see the problem, its already attached here somewhere, just search my name..
meanwhile back at the farm, I put 12.2.35 se on the switches and it seems to be running fine so far.
Sunbeam,
Are you having nightmares about Cisco's Feature Navigator? :-) Relax, the above reference is to the release notes.
dahuja
I would suggest you to go in for 12.2(25) SEE2
as it has been there for good amount of time and its a stable image where as 12.2(35)SE2 has just released couple of days back so it will not be an ideal image to go in for.
Here are the feature differences as requested by you
Unique Features in 12.2( 35) SE2 ADVANCE IP SERVICES
Access Switch Device Manager (SDM) Template
Authentication Proxy Accounting for HTTP
Configuration Change Notification and Logging
Cross-Stack Link Aggregation Control Protocol
DHCP - Configurable DHCP Client
Diagnotics Options on bootup
Enhanced Tracking Support
Fast Stack Image Upgrade
Firewall Authentication Proxy
Flex Link Bi-directional Fast Convergence
Flex Links Interface Preemption
IEEE 802.1Q Tunneling
IEEE 802.1s - Multiple Spanning Tree (MST) Standard Compliance
IEEE 802.1x - Auth Fail Open
IEEE 802.1x - Auth Fail VLAN
IEEE 802.1x - Wake on LAN Support
IEEE 802.1X Multi-Domain Authentication
IGMP Fast Leave
IP Phone Enhancement - PHY Loop Detection
IPv6 Routing: Route Redistribution
IPv6 Security: Secure Shell SSH support over IPv6
IPv6 Services: Cisco Discovery Protocol (CDP) - IPv6 Address Family Support for Neighbor Information
MAC Authentication Bypass
MLD Snooping
NAC - L2 IEEE 802.1x
NAC - L2 IP
NAC - L2 IP with Auth Fail Open
NSF - EIGRP
NSF - OSPF
NSF Awareness - BGP
NSF Awareness - OSPF
Per Port Per VLAN Policing
Secure Copy (SCP)
Secure Shell SSH Version 2 Server Support
SRR (Shaped Round Robin)
Switching Database Manager (SDM)
UDI - Unique Device Identifier
dahuja
Continued Message
Unique features in 12.2(25) SEB4 ADVANCE IP SERVICES
CEF/dCEF - Cisco Express Forwarding
Configurable IGMP Leave Timer
Dynamic ARP Inspection
EIGRP Stub Routing
Enhanced IGRP (EIGRP)
HTTP Security
IGMP Querier
IGMP Snooping
IGMP Throttling
IP Enhanced IGRP Route Authentication
MPLS VPN support for EIGRP between Provider Edge (PE) and Customer Edge (CE)
NSF Awareness - EIGRP
Commom Features in Both ADVANCE IP SERVICES
AAA Server Group
AAA Server Group Enhancements
Ability to limit console and telnet login attempts
ACL - Improved Merging Algorithm
ACL Sequence Numbering
Address Resolution Protocol (ARP)
ARP Optimization
AutoInstall Using DHCP for LAN Interfaces
AutoQoS - VoIP
BGP
BGP 4
BGP 4 Multipath Support
BGP 4 Prefix Filter and In-bound Route Maps
BGP 4 Soft Config
BGP Conditional Route Injection
BGP Configuration Using Peer Templates
BGP Convergence Optimization
BGP Cost Community
BGP Dynamic Update Peer-Groups
BGP Hide Local-Autonomous System
BGP Hybrid CLI Support
BGP Increased Support of Numbered as-path Access Lists to 500
BGP Link Bandwidth
BGP Multipath Load Sharing for Both eBGP and iBGP in an MPLS-VPN
BGP Named Community Lists
BGP Next Hop Propagation
BGP Policy Accounting
BGP Prefix-Based Outbound Route Filtering
BGP Restart Neighbor Session After max-prefix Continued in next reply
dahuja
Continued Message
BGP Route-Map Continue
BGP Route-Map Policy List Support
BGP Soft Reset
Broadcast/Multicast Suppression
CDP (Cisco Discovery Protocol) Version 2
CEFv6/dCEFv6 - Cisco Express Forwarding
CGMP - Cisco Group Management Protocol
Cisco StackWise Technology
Class Based Ethernet CoS Matching & Marking (802.1p & ISL CoS)
Clear Counters Per Port
CLI String Search
Commented IP Access List Entries
DHCP Server
DHCP Snooping
Dynamic Trunking Protocol (DTP)
Encrypted Kerberized Telnet
Enhanced Password Security
ErrDisable Reactivation Per Port
ErrDisable timeout
EtherChannel
EtherChannel - Flexible PAgP
EtherChannel Enhancement - Single Port Channel
Etherchannel Guard
Fallback Bridging
Fast-Switched Policy Routing
Flex Links
FTP Support for Downloading Software Images
HSRP - Hot Standby Router Protocol
HSRP - Hot Standby Router Protocol and IPSec
HSRP support for ICMP Redirects
HSRP support for MPLS VPNs
IEEE 802.1p Support
IEEE 802.1Q VLAN Trunking
IEEE 802.1s VLAN Multiple Spanning Trees
IEEE 802.1t
IEEE 802.1W Spanning Tree Rapid Reconfiguration
IEEE 802.1x - VLAN Assignment
IEEE 802.1x Authenticator
IEEE 802.1x RADIUS Accounting
IEEE 802.1x with Port Security
IEEE 802.3ad Link Aggregation (LACP)
IEEE 802.3af Power over Ethernet
IEEE 802.3x Flow Control
IGMP State Limit
IGMP Version 1
IGMP Version 2
Interface Range Specification
IP Multicast Load Splitting across Equal-Cost Paths
IP Multicast over 1483 VC Mux Encapsulation on ARMII
IP Named Access Control List
IP Routing
IP Source Guard
IP Summary Address for RIPv2
IPv6 (Internet Protocol Version 6)
IPv6 Data Link: VLANs using Cisco Inter-Switch Link (ISL)
IPv6 Data Link: VLANs using IEEE 802.1Q Encapsulation
IPv6 MTU Path Discovery
IPv6 Neighbor Discovery
IPv6 Routing: OSPF for IPv6 (OSPFv3)
IPv6 Routing: RIP for IPv6 (RIPng)
IPv6 Routing: Static Routing
IPv6 Services: AAAA DNS Lookups over an IPv4 Transport
IPv6 Services: DNS Lookups over an IPv6
See next reply
dahuja
Continued message
Transport
IPv6 Stateless Auto-configuration
IPv6 Switching: CEF/dCEF Support
IPv6: ICMPv6 Redirect
IPv6: Neighbor Discovery Duplicate Address Detection
ISL VLAN
Jumbo Frames
Kerberos V client support
L2PT - Layer 2 Protocol Tunneling
Message Banners for AAA Authentication
MPLS VPN - Inter-Autonomous System Support
MPLS VPN - OSPF PE-CE Support
Multicast BGP (MBGP)
Multicast Etherchannel Load Balancing
Multicast Source Discovery Protocol (MSDP)
Multicast Subsecond Convergence
Network Time Protocol (NTP)
OSPF
OSPF Forwarding Address Suppression in Translated Type-5 LSAs
OSPF Inbound Filtering using Route Maps with a Distribute List
OSPF Not-So-Stubby Areas (NSSA)
OSPF Stub Router Advertisement
Packet-Based Storm Control
Parse Bookmarks
Parser Cache
Performance Enhancements for IOS ACL
PIM Dense Mode State Refresh
PIM MIB Extension for IP Multicast
PIM Multicast Scalability
PIM Version 1
PIM Version 2
Policy-Based Routing (PBR)
Port Security
Private VLANs
QoS Policy Propagation via Border Gateway Protocol (QPPB)
QoS Priority Percentage CLI Support
RADIUS
Rapid-Per-VLAN-Spanning Tree (Rapid-PVST)
Reduced MAC Address Usage
Remote SPAN (RSPAN)
RIP
RMON events and alarms
Secure Shell SSH Version 1 Integrated Client
Secure Shell SSH Version 1 Server Support
Smart Port
SNMP (Simple Network Management Protocol)
SNMPv2C
SNMPv3 (SNMP Version 3)
Spanning Tree Protocol (STP)
Spanning Tree Protocol (STP) - Backbone Fast Convergence
Spanning Tree Protocol (STP) - Loop Guard
Spanning Tree Protocol (STP) - Portfast
Spanning Tree Protocol (STP) - PortFast BPDU Filtering
Spanning Tree Protocol (STP) - Portfast BPDU Guard
Spanning Tree Protocol (STP) - Portfast Support for Trunks
Spanning Tree Protocol (STP) - Root Guard
Spanning Tree Protocol (STP) - Uplink Fast Convergence
Spanning Tree Protocol (STP) - Uplink Load Balancing
Spanning Tree Protocol (STP) Extension
Standard IP Access List Logging
STP Syslog Messages
Stub IP Multicast Routing
Switch Port Analyzer (SPAN)
Switch Provisioning for Stackwise technology
Tacacs SENDAUTH function
Tacacs Single Connection
TACACS+
Time-Based Access Lists Using Time Ranges
Transparent Bridging
Trusted boundary (extended trust for CDP devices)
Tunnel Type of Service (TOS)
Unicast Mac Filtering
UniDirectional Link Detection (UDLD)
Virtual Profile CEF Switched
VLAN Access Control List (VACL)
Weighted Tail Drop (WTD)
Deepak Ahuja
Cisco TAC
aLTeReGo
I should have mentioned that I'm running IPBASE code and the purpose of this exercise is to upgrade code to conform with the DST changes happening on March 7th 2007. Does that change anyone's responses?
